07-03-2015, 03:50 PM
Jinx! 3070 DSL without 120 v today- fine yesterday!
Yesterday I bragged on my Sunseeker having no major problems - today no 120 v eventho I'm hooked up( and have been for over a month). So called FR tech help and after testing several things it looks like either my cord or the transfer switch. It's hot here! I called thr nearest FR dealer in Sheridan, Wyo but so far no call back to my voice mail. I'm still under warranty, so I guess I'll just wait to hear from him( probably after the holiday weekend). At least every thing works on the genny, so I'll have coffee . Any thoughts? Thanks , my DH is in Cali, so I'm on my own.
2014 Sunseeker
3170ds (Suzuki Samurai 1986 toad)
Gary and Dottie, fur babies Doodle(corgi) and Beau(yellow lab)
07-03-2015, 03:55 PM
Sorry about double post!
2014 Sunseeker
07-04-2015, 12:58 PM
Now the generator won't stay on ! First time boondocking even if it is in a CG. At least we're still under warranty. Hope Dalton's Rv in Sheridan can fix it Monday as I'm living in it for now!
2014 Sunseeker
07-04-2015, 01:15 PM
2012 Solera
Maybe an extension cord from the campground power pole to run critical stuff until you can get it fixed? Unplug what you need to run from the camper electrical and plug into the extension cord?
JLeising
2012 Solera "S"
Calif SF Bay Area
07-04-2015, 02:30 PM
A neighbour in the CG suggested that I prop open the door to the generator compartment -that maybe it was over -heating. Did it -so far, so good! The ac feel so good. Thanks for suggestions about extension cord-I'll try that if this doesn't work out.
2014 Sunseeker
07-04-2015, 03:32 PM
Nope! Genny ran for 3hrs with ac on then stopped dead. Won't start again. We'll see what they say Monday. It's hot here!
2014 Sunseeker
07-04-2015, 05:01 PM
Wait till next year...
How much fuel in Ford. Generator cuts out at 1/4 tank
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
07-04-2015, 07:07 PM
It's full.
2014 Sunseeker
07-05-2015, 11:13 AM
What door did you prop open? Compartment door or the removal cover that access the generators oil fill & air filter? The generators service cover needs to always be on while running for proper air flow.
2011 Sunseeker 3170DS - 30,000 miles explored
07-05-2015, 01:29 PM
Sure sounds like the transfer switch. Might take the cover off and look for a loose connection.
07-07-2015, 03:31 PM
Dalton's found the problem-a loose wire at the wall plug-probably from the factory. At least I didn't have to buy a new transfer switch $ . I will be sending the $127 bill to warranty. There was also a 12v connection without a wire nut , they fixed. Quality Control?
2014 Sunseeker
07-08-2015, 12:56 AM
Just curious, which wall plug? and any idea how Dalton found it?
07-08-2015, 02:11 AM
Was it the reason generator wouldn't run?
Mary and Me
07-08-2015, 12:30 PM
Wow on two points:
Garrette and Ned, 1:56 and 3:11 am?
On the plug can we assume there was something actively plugged in the socket drawing a load? I can't image a partially connected outlet having any effect on the power service.... but it does seems reasonable if the misbehaving wire was touching something it shouldn't.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
07-08-2015, 12:38 PM
Originally Posted by Hoglou
Wow on two points:
They went to bad after the evening news
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
07-08-2015, 02:21 PM
Actually was the call of nature. Mine was just an hour latter than Garrette. Too many Blue Moons
Mary and Me
07-08-2015, 09:02 PM
Woking the night shift this week.
07-08-2015, 10:56 PM
When I said wall plug I meant where the electric cord from the hookup plugs into the motorhome! Sorry about the confusion. Anyway, they looked at the transfer switch under the bed ( A pita to get to)and found that it had power to only one side. The unhooked the switch and tried just 120 from the cord but that didn't work either. They tested the cord and it was okay, so they looked at wiring at the plug in out side the wall of the MH - sure enough ,a wire had not been tightened down- tightened it and everything including the generator works! They also found two wires for 12 v that went to the fuzes that had no wire nut, and fixed that. I guess the electrical installer was in a hurry when he did my MH . One of those intermittent things that are hard to figure.
2014 Sunseeker
07-09-2015, 10:54 PM
Thank you. I will be checking mine before next trip.
07-10-2015, 06:28 PM
Ya, I understand that. Last spring I was washing my truck in the driveway at 3:30 am. The house lite like a xmas tree, I had talk radio on and it was extremely low. I did learn we have a deputy that makes rounds in the county. He slowly went by with the window down. I said I didn't like water spots from the sun.. He just waved and shook his head...
