Just added a built-in voltmeter wired directly to the batteries. I was tired of taking the step off every time I was boondocking to check the state of charge. The toggle switch obviously turns the voltmeter on and off. Mounted the voltmeter and switch to a standard house wallplate. Had to use a dremel so they would fit on the wallplate.
Very nice professional looking installation. Did you have any problems routing the wiring down to the batteries?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
Not really. I already installed an inverter in the compartment to the left of the door. So I dropped a line into that compartment and hooked it to the battery cables that I already had running directly to the batteries.
Nice little install. Been meaning to do the same...unscrewing and removing step to check batteries getting old. Now I have to copy your install.
Grumpy
Nice install!
But wall plate looks about $5 more than big box stores. Search Results forÂ*80405Â*at The Home Depot
should have different colors also.
Another nice inexpensive MOD
Could not find this style in black at HD or BLowes. No 2 gang box. Wallplate screwed to the wall. Didn't see a need for it since it was 12v. I did install a 1 gang box for the inverter outlet I installed below this though.
