Old 11-15-2014, 10:44 AM   #1
Led push lights - how to remove to replace a bulb
How do you remove these to replace a bulb? I figured you need to put a screwdriver or something flat under the entire unit and pry it away from the ceiling but it wasn't coming "easy" and I figured I would ask before I damage the light.
jjlavin is offline   Reply With Quote
Old 11-15-2014, 10:48 AM   #2
Ford Idaho's Avatar
Should come off if you squeeze it together in the middle and pull down.
Old 11-15-2014, 10:50 AM   #3
Hmmm. Tried but I don't think so. It's very inflexible. nothing that "gives" when I squeeze it.
Old 11-15-2014, 10:54 AM   #4
Squeeze the lens only.
Old 11-15-2014, 10:54 AM   #5
Ford Idaho's Avatar
Ok, try pushing in and down hard on one side.
Old 11-15-2014, 10:54 AM   #6
Wait I just got it. Put a small screwdriver in between the frosted dome and the housing. Easy pry and it pops out
Old 11-15-2014, 11:03 AM   #7
Check the wiring in those things. We had trouble with one in ours and was able to fix it by just checking the wire connections.
jst3 is offline   Reply With Quote
Old 11-15-2014, 11:06 AM   #8
Ford Idaho's Avatar
Was it a bad wire crimp on the connection?
Old 11-16-2014, 09:52 PM   #9
I really don't know. It wouldn't turn on sometimes so I took it apart to have a look. It's worked since I put it back together. I didn't redo any connections or anything like that. Just made sure the existing connections were tight.
Old 11-18-2014, 01:12 AM   #10
Motorized GM
I don't think anyone was actually looking at the picture when they answered. They were telling you how to pull the lens off of a standard run of the mill pancake light...not the super cool, push on/off Sunseeker LED super fantastulistic light.
I did answer this in another post a while back...but it looks like you figured it out.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-18-2014, 07:24 AM   #11
Now I want to know how to dial down the brightness of these things. Holy cow. I feel like I'm on stage with theses lights! Thinking of putting a light coating of a tan spray paint. I thought I could swap the bulbs but... the thing underneath clearly is not designed for a simple light bulb swap. Any recommendations?
Old 11-18-2014, 08:37 AM   #12
Motorized GM
They can be individually controlled by pushing on the lens. If I have the living room lights on, I just turn a couple of them off if its too bright.
Old 11-18-2014, 08:45 PM   #13
Funny, the lights being too bright was one of my complaints.
On the other hand, my wife loves that they are nice and bright.
So if you have a choice of who to please.... well you know the answer.
The advantage of the old fight fixtures is they often had two bulbs. So if you wanted a dim one for TV watching or over the bed for example, you could just remove a bulb or install a lower watt bulb.
Old 11-19-2014, 05:51 AM   #14
Unfortunately my wife agrees it's too bright
led, light
