Old 07-23-2018, 11:58 AM   #1
Leveling jacks
On my 3050S only one leveling foot came down on the back. As a result the one jack that was down bent away from the frame. It looks like the frame actually bent away. Of course now it comes down screwed to one side. Any suggestions? Click image for larger version
ID:	180916Click image for larger version
DrJMB is offline   Reply With Quote
Old 07-23-2018, 04:38 PM   #2
Duckogram's Avatar
It appears that along side with your jack that failed, you have bent frame mount and broken jack mount. Also noted is significant corrosion. You need a full shop to fix that and I suggest you stop using it as it could cause the chassis frame to twist. YMMV
ILB ( | )
Old 07-23-2018, 05:11 PM   #3
I figured. Back to the dealer.
Old 07-25-2018, 12:58 AM   #4
Kirk S's Avatar
X2!
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
jacks, leveling
