Old 05-14-2013, 09:35 AM   #1
Mike & Molly's Avatar
Question Leveling The MH
I purchased leveling blocks & understand how they are used.
IE: under both tires if used in the rear.
Can someone explain the proper method to use in the initial set up.
Do you use a carpenter level on the floor inside, countertops or the outside edge of a slide out. (retracted).
Then where is the best place to permanently install the bubble levels.
Inside or outside and where?
Thanks Much For Any Help.
2013 Sunseeker 3010DS
Mike & Molly is offline   Reply With Quote
Old 05-14-2013, 09:49 AM   #2
I use a 2 foot carpenter's level. I place it on the outside trim rail (which I determined was an appropriate place-same as interior floor) and on the back bumper for side to side. Never bothered with stick on levels.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 05-14-2013, 10:05 AM   #3
i used 2 levels on initial set up one on counter and one on floor then mounted my stick on levels behind drivers door.
lbrunning is offline   Reply With Quote
Old 05-14-2013, 11:56 AM   #4
MotocrossCamper's Avatar
I leveled mine at home and put 2 bubble levels on the outside corner right outside the drivers door. I bought the ones that show how many inches you are out of level each way. They are pretty accurate. It only takes me about 2 minutes to level because I already know how far to drive up my homemade ramps.
MotocrossCamper is offline   Reply With Quote
Old 05-14-2013, 12:03 PM   #5
Always level the floor of the RV because that is where you will feel it if it's off. Countertops, trim etc can be off a little relative to the floor. Once you have it where you want it, you can install bubble level indicators on the outside if you want.
ATVer is offline   Reply With Quote
Old 05-14-2013, 10:43 PM   #6
statgeek's Avatar
The most recent Good Sam magazine had an article about leveling --suggested that you put your bubble level in the freezer--apparently bc they require level to work properly and have a long life. Seemed strange to me, but those units r pricey, so what the heck...
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
statgeek is offline   Reply With Quote
Old 05-15-2013, 08:59 AM   #7
Motorized GM
I drink a beer. Set the empty bottle on the table and see how fast it rolls. Front to back, side to side. Rocking back and forth is dead on...slight roll is within tolerance. Sometimes I drink two beers before leveling so that #1. I can roll both bottles at the same time. (Quite a time saver) #2. I don't care quite as much.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-15-2013, 04:55 PM   #8
I like the way you think!
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 05-16-2013, 11:41 AM   #9
Plain Old Member
Did the same is lbrunning and Motocross. Leveled by floor and counter average, stuck levels just behind driver's door. There are times we've just used blocks under tires even though we have the Bigfoot system. Sometimes it's just as quick due to the short stroke of the hydraulic jacks and having to retract and add blocks anyway. My wife commented real quick that we used to set up trailers a lot faster, without the auto level stuff. I can agree.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-16-2013, 12:06 PM   #10
Phat Phrog Stunt Crew
awwall's Avatar
Just make sure refrigerator is level and you are good to go...
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-16-2013, 12:09 PM   #11
Rugged Brown's Avatar
Should I expect beer as a standard option on the Sunseeker line of products?
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-16-2013, 01:47 PM   #12
Motorized GM
I've been pushing for that for a long time. If you order from one of my dealers...I'll be sure to add that as a "special leveling option".
Old 05-16-2013, 06:05 PM   #13
A lot is always talked about when it comes to your fridge being level. My biggest concern is the stress on my slides if they are all out of whack. I've worked on them myself and it isn't something I enjoy so I figure the easier time they have traveling in and out the better!
