Old 10-04-2012, 08:41 AM   #1
Absnova's Avatar
Lighting help
eaching out to the wonderful forum friends for help once again. On our 2012 sunseeker was coming home and realized only had running lights on the driver side. No front or rear turn signals or brake light. Found a busted bulb full of water in a tail light. Checked all the fuses and all are good. Replace the bulb but still nothing. Really want to fix if ourselves instead of dealership that takes months. Thank you in advance for help!!
Absnova is offline   Reply With Quote
Old 10-04-2012, 11:21 AM   #2
Coachmen Adrenaline
Which fuse block were you checking? There is one under the hood and also one under the driver seat. Check out A-50 here, as it shows which fuses under seat control the different parts of the lighting system: http://www.gmupfitter.com/publicat/2...l%20112911.pdf
Hopefully that helps you out.
jamiller45 is offline   Reply With Quote
Old 10-04-2012, 01:32 PM   #3
Absnova's Avatar
Thank you we checked quite a few but not that one.
Old 10-04-2012, 03:13 PM   #4
Absnova's Avatar
Once again the forum to our rescue! Thank you certainly much found the burnt fuse!
Old 10-05-2012, 06:40 AM   #5
Coachmen Adrenaline
You are welcome. Glad I could help you out.
