Old 02-23-2018, 09:53 AM   #1
Lost microwave and 110 power
While using generater lost both 110 and microwave power. The microwave breaker was not popped nor is bathroom gfi . Is ther a fuse or breaker vfor 110 power in the generater compartment on a 2800qs?
Any help will be appreciated. All other power seems ok.
Tom C 47 is offline   Reply With Quote
Old 02-23-2018, 09:58 AM   #2
Flybob's Avatar
Do you have any 120VAC items ( outlets /appliances ) that work or is it only 12V items ( lights , water pump)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-23-2018, 09:59 AM   #3
A32Deuce's Avatar
There is a breaker on the gen. itself. Mine is down on the right hand side looking at it. Not at rv now to look.
A32Deuce is offline   Reply With Quote
Old 02-23-2018, 10:05 AM   #4
sgtlm17's Avatar
Yes breaker on the generator itself make sure you turn it all the way off then back on.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 02-23-2018, 10:14 AM   #5
Thanks the circuit breaker is not easy to see but found it and reset and all is good! You folks on this forum are the best!
Old 02-23-2018, 10:16 AM   #6
sgtlm17's Avatar
Glad it solved the problem
2011 Jeep JK Toad
Old 02-23-2018, 10:18 AM   #7
Mr. Dan's Avatar
BTW, you need not distinguish between 110v and microwave power. They are the same. The microwave runs off a 110v outlet, too.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 40; Booked for 2022 = 70
power
