I was working in the RV the other day (at our storage location) and it was warm so I turned on my Onan 4000 Generator. It started like always with no problem. Once on, I turned on the A/C to cool things off. A/C came on fine. I was working on the TV cable, rewiring the cable so the TV was on. And of course the microwave comes on as normal but no used. About 5 minutes into it I lost all power but the generator stayed on. I checked all breakers, nothing tripped so I went out and checked the breaker which wasn't tripped. I turned off the generator. Moved the breaker on the generator from on to off and back on. Went inside and rechecked all the breakers, turned off and turned back on. They seem stiff. Even checked the fuses since I was in the fuse box. All were good. I went out and checked the plug, pulled it out, checked the prongs, all good and plugged back in the receptacle. I even turned off the battery disconnect and turned back on. I know I have power from that as I can use some lights. Turned the generator back on and nothing. So not sure what to check next.
I've had some tell me to check the spade connector breaker...replace the breaker on generator as it could be bad...someone mentioned the transfer switch...which I'm not sure where it is located.
Other suggestions appreciated and where the transfer switch may be located. We recently acquired this Rig (What they call a mini RV) and it didn't come with any manuals so I've been trying to find everything online. Trying to find the fix as I live in Key West and RV mechanics are not very available in our area as they would be on the mainland. Thanks all in advance.
