Originally Posted by davegood
I have a 2011 Sunseeker 2300. Does the low point hot water drain drain the water heater? it is a real pain removing the anode rod.
Tank type water heaters "can" be drained using the low point drains if plumbing/piping conditions allow and most do but... not EVERY R/V is plumbed the same so plumbing routing can affect that ability.
With that said, it is never a good idea to try and drain the water heater with the low point drains. When doing so, the fill/mix tube in the water heater acts as a suction straw, sucking crap out of the bottom of the water heater where much of the crap remains in the plumbing and then gets redistributed back into the system where it clogs faucet aerators and toilet valves.
It is always best to drain the water heater by the anode or the drain plug or put the water heater into bypass and just leave it full when opening the low point drains when necessary. Once we fill our water system for the season, we never drain it until we winterize.
Here is a photo, looking into the bung where the anode resides in a Suburban water heater showing the fill/mix tube (back wall of tank) and how it sits low enough in the tank to suck the crap back into the system.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
