Old 10-20-2018, 09:20 AM   #1
Low pressure grill on 2015 Sunseeker 3010ds not working
Our grill is not firing up. I want to troubleshoot the issue. Here's what I know :
- there is propane. I fired up my inside stove.
- the connections are tight on the hose
- the valve is open
I am trying to figure out if I have a house problem, a grill problem, or the valve on the motorhome problem.
If I disconnect the hose and open the valve, how can I treat that gas is minimally coming out of the valve?
Then assuming it is, how can I connect the hose and test its coming out of the other end of the hose?
Any help would be greatly appreciated.
jjlavin is offline   Reply With Quote
Old 10-20-2018, 03:34 PM   #2
Chief tinkerer
Gidyupgo's Avatar
jjlavin, was it working and then quit? Just to follow up, there is a valve where the quick disconnect connects to the coach that must be open and likely a valve at the quick disconnect at the grill that must be open. Make sure these "quick disconnects" are fully snapped on.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
pressure, sunseeker
