Old 08-09-2013, 07:19 PM   #1
wplate's Avatar
Magnadyne radio Fuse?
My Magnadyne stopped working today-- it was on earlier, I turned it off by holding the power button for a beat, but now won't turn on-- I wonder how to check its fuse.
The Ford owner manual says the radio is fuse 41 on the inside fuse block but that fuse is intact. I doubt it is that fuse anyway since the Magnadyne isn't switched with the ignition.
Do you know which fuse to check? Or other suggestion for troubleshooting a Magnadyne that doesn't turn on?
2013 Sunseeker 2860DS
2014 Jeep Wrangler Unlimited
wplate is offline   Reply With Quote
Old 08-09-2013, 08:12 PM   #2
There is a fuse on the back of the radio itself (15 amp). Likely will have to remove the radio from the dash to reach it. Before looking for that, try pressing the reset button on the bottom left side of the face plate. Use a ball point pen or paper clip to press it (small hole).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
