Originally Posted by Duckogram
Beside the fact that you have very little ground clearance and can permanently twist your extended frame, the widest shoes that will fit your hub centering wheels is 225mm. Your dually spacing is designed for that. I do not define boondocking as an activity that would require rock chucking treads.
Thanks, Duck. I'm having the WeldTec 6" lift and full suspension upgrade done at the same time. After speaking to Tire Rack, Discount Tire and WeldTec the concensus is that the biggest is the 235-85-16 without requiring a 1/4" spacer on the rear hubs. As far as boondocking goes, we will be doing gravel and forest roads (nothing that will test the torsion limits), so I wanted more grip than the very mediocre stock Hancooks provide. The Vredestein Pinza AT is what I've decided on, which is 90/10 highway/off-road rated. Thanks again for your input!
