07-29-2020, 10:33 PM
Maxxair Maxxfan Deluxe Wiring Question
Installing a Maxxair Maxxfan Deluxe in place of useless vent in 2017 Forester 2401R. I pulled down the wiring to find 3 black 3 white wire each tied together. Since I am a mere novice electrician, I was hoping someone have suggestions for the connection. Should I connect the 2 wires from the fan to each of the respective 3 wire bundles, or do I need to break out a single black and white wire for the connection....
Picture of the wires attached.
07-30-2020, 07:56 AM
this is just a guess. do not take it for gospel.
did you already remove the existing vent? including disconnecting the vent wires? of is the vent still there and are the vent wires still connected?
i would guess that the new fan wires would connect to the same places that the existing vent got its power from.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-30-2020, 08:03 AM
As already said above, if your vent already has a fan, I’m going to guess that one of those black wires and one of those white wires goes to the existing fan. Disconnect the old fan from those two wires and connect the new fan to the same two wires.
If your old vent did not have a fan, then you can either add the new wires to the groups of three, so you have four blacks and four whites connected together, or you can tap into one of the blacks and one of the whites and tie in your new fan wires. All that matters is than in the end, there is a connection between all whites, and between all blacks, and no loose wires hanging.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
07-30-2020, 08:11 AM
Sorry, I should have been clearer. I removed a manual vent (no fan). The wire picture shows what is under the interior trim. None of the wires were previously connected...thanks.
07-30-2020, 08:20 AM
Certified Curmudgeon
Tap
I did the same thing. I suggest using a 3M T-Tap to make things easier.
I will add a link to my post with photos on the subject shortly.
Edit: https://www.forestriverforums.com/fo...ml#post1789460
Those wires are normally for ceiling lights and depending on your floorplan, maybe the bathroom vent fan as well.
Mike Dropped
07-30-2020, 08:21 AM
So, the other end of those wires are not connected to anything?
07-30-2020, 08:43 AM
i'd be concerned about using those wires! black and white with those type of connectors are normally 120 vac wires. but this is an rv, who knows by just looking at them? if it was a manual vent there may not even be 12 vdc wires to tap into!
07-30-2020, 08:58 AM
Shocking
I know of no RV manufacturers that would use a vent hole as a 120v junction box. If the coach was prewired for a 2nd A/C there would be a 12ga 2 conductor NM wire neatly capped and tucked behind the opening. The OP has a MBS which
is a 30amp unit and had no option for 50amp service.
Mike Dropped
07-30-2020, 09:23 AM
Clarity
You can (and should) use a meter to make sure they are not switched before you tap in. I’m 99% sure that they are not but you need to be 100% sure. I suggested t-taps because I used wire nuts and they were difficult to stuff in behind the garnish. You might want to check voltage as well to assuage Chickdoe’s concern as well. Just to be über safe.
_________________
Mike Dropped
07-30-2020, 10:28 AM
I'm not sure anymore, but I thought they used Romex for the 120V conductors?
We had one of the 120V outlets fall out of the wall in our bedroom, and when I put it back in, I think it was connected with Romex wire. But I could be wrong!!
Brian & Becky
2018 Avenger ATI 27RBS
07-30-2020, 10:56 AM
Brand
Romex is a brand name for NM or non-metalic wire invented by Rome Wire
and Cable in Rome, NY. I worked for Circle Wire and Cable distributor, their competition, back in the 60’s
Mike Dropped
07-30-2020, 12:37 PM
It's a 12 volt wire. 120 v is romex. I had the same bundle when I replaced my fan. Mine had 4 white and 4 black wires. I cut the old wires off the fan and connected them back to the bundle. What I'm saying is those are the wires you need.
07-30-2020, 12:42 PM
Yep, Kleenex, Xerox, etc.
May not be the "proper" name, but it is the name that most efficiently conveys the information to the most people.
Brian & Becky
07-30-2020, 01:25 PM
On the ranch.
Somebody has been Branded. Kudo’s to the Southwire marketing team for
successfully making Romex the go to name for non-metallic sheathed wire (aka house wire). As long as the point was understood by the OP, all is good.
Mike Dropped
07-31-2020, 02:19 AM
In which case you could break out yoru trusty old Multimeter and determine if you had 120 or 12 volts!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-31-2020, 07:40 AM
Commercial Member
Maxx air fan should have two wires Black and white. disconnect old vent and reconnect the exact same way. Black to the two black and white wires and white to the two white wires.
hope this helps
Kary Katzenberger
Product Manager
Forest River Class C Division
07-31-2020, 08:30 AM
if it was A/C it would be Romex not free wires like that. take a meter to it and see.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-31-2020, 08:33 AM
hope this helps
That would be true if he had a vent fan however he only had a vent.
Mike Dropped
07-31-2020, 08:35 AM
Romex is NM and I already said that... nothing more to say here unless the OP chimes in.
Mike Dropped
07-31-2020, 02:53 PM
Duck,
I think you probably lost that war before you fired your first shot...
Peace...
Brian & Becky
