Old 09-22-2020, 09:41 PM   #1
Microwave issues
Our Furion microwave does everything but heat food.
Ross6250 is offline   Reply With Quote
Old 09-23-2020, 07:55 AM   #2
SeaDog's Avatar
time to pull it and get a new one.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-23-2020, 08:10 AM   #3
D W
D W's Avatar
X2. Not really a whole lot of info for us to help the OP.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 09-23-2020, 08:38 AM   #4
Furrion microwave
Display works, can enter all selections, plate rotates, just doesn’t heat the food
Old 09-23-2020, 12:18 PM   #5
5er_tom's Avatar
Yup, it is dead. We had the same issue at the house. Your only option is to replace it.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is online now   Reply With Quote
Old 09-23-2020, 01:25 PM   #6
Ambassador Member
Duckogram's Avatar
The Vast Unknown
The problem you describe leads me to believe that the issue is in the high voltage section only. There MAY be a shielded fuse near the Magnatron that has blown but newer models do not use that secondary protection. If it is not a fuse it is still repairable however unless you have the KSA’s to do it yourself, it is not cost effective for just a plain microwave. Might be different if it was a convection/grill/microwave combo. Unfortunately, you do not give much info so you get generic answers. Even a year would be a clue. Might be under warranty rendering this entire conversation moot.
Ducky
‘18 Sunseeker 2800QS
Towing Smart
No PM’s.
Old 09-23-2020, 06:06 PM   #7
A common cause of microwave not heating the food is a bad magnetron. If you are really handy and determined, it could probably be repaired, but the easier solution is to replace the whole microwave oven.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 09-23-2020, 06:12 PM   #8
NMWildcat's Avatar
Yep, probably cheaper, faster,and less aggravating to just replace it than repair it.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-24-2020, 01:51 PM   #9
Commercial Member
It sounds like it may be kaput.
Kary Katzenberger
Product Manager
Forest River Class C Division
karykatz is offline   Reply With Quote
microwave
