[QUOTE=larry.mahoney]
Originally Posted by Outlaw7
Originally Posted by larry.mahoney
Could you send a picture or give more information on your 6v battery modification. You just raised the step only? I want to do the same.
Hi Larry
Pretty simple process. I cut some 2x2 ( which is actually 1.5 sq ). And lined the bottom of the step cover. I used Gorilla Glue and then clamped it for the day. Trimmed excess off with a knife.
Re-drill the 2 screw holes ( through the wood). And then you will need to replace the screws with longer ones.
I think I also put down a thin strip of foam weatherstrip (1/8")
Install the 2 6V batteries upright and wire them accordingly. You can find that online. Just need to buy 1-2 battery leads.
The end result is the step cover is raised 1.5" and you won't even know it. The step cover has a 2" wrap on the front and perfectly hides the wood
Hope this helps. It was an easy mod and even though I'm not a Rocket Scientist the AH prove the results w better battery power
I going to do it. I have a progressive 60 amp converter, did you upgrade yours? We boon-dock so recharge by honda generator. How much power do you use before recharge? Wife likes to use the 90 watt TV.
Hi Larry
