Old 04-03-2018, 11:49 PM   #401
Originally Posted by sgtlm17 View Post
Yes I knew I couldn't sit on that couch for one minute. I got the theater seating even though I lost a sleeping area
I just realized, I never asked what theater seating you got? I am about to switch to theater seating as well.
AbdRahim is offline   Reply With Quote
Old 04-04-2018, 01:54 AM   #402
sgtlm17's Avatar
It came from factory with OEM recliners.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 04-04-2018, 10:54 AM   #403
Tombsy's Avatar
The ones sitting in my garage, are Thomas Payne “Momentum Theater Marquee Collection” in Jaleco chocolate, hard to find a good picture of the whole unit. There is 70” of room where the couch is, I double checked at the showroom and they should fit no problem with the wider centre console.
https://youtu.be/jq_gHXyqiJI
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 04-04-2018, 11:04 AM   #404
sgtlm17's Avatar
Originally Posted by Tombsy View Post
The ones sitting in my garage, are Thomas Payne “Momentum Theater Marquee Collection” in Jaleco chocolate, hard to find a good picture of the whole unit. There is 70” of room where the couch is, I double checked at the showroom and they should fit no problem with the wider centre console. Attachment 167185
They look more comfortable than what I have. Let us know!
2011 Jeep JK Toad
Old 04-04-2018, 11:21 AM   #405
Thanks. I am going to look at this one and a Lambright. I want to see how they feel before I buy. I must say the Thomas pPayne gets rave reviews. I am also thinking of the ultra pleather, since I hope to keep this for another 8 years or so. Man I look forward to the comfort. I will also investigate making the dinette seating more comfortable.
Old 04-09-2018, 09:54 PM   #406
Anyone know where the vacuum breaker is located?
Old 04-10-2018, 07:10 AM   #407
Ambassador Member
Duckogram's Avatar
A vacuum breaker is usually found on the spigots at RV parks. If you are looking for the plumbing vent that does not go through the roof, look under the sink in the cabinets.
Pics are under kitchen and bathroom sinks.
Curious as to what kind of mod you plan. Inquiring minds...
ID:	167714   Click image for larger version
Ducky
‘18 Sunseeker 2800QS
Towing Smart
No PM’s.
Duckogram is online now   Reply With Quote
Old 04-10-2018, 08:59 AM   #408
RETIRED AND LOVING IT
n-e-d's Avatar
Vacuum breaker on black tank flush should be in close position to toilet /black tank .Mine is in a closet beside toilet
Mary and Me 😷😷 Stay Safe
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT "Red Roamer"
"I am in the prime of my decrepitude"
n-e-d is offline   Reply With Quote
Old 04-10-2018, 06:06 PM   #409
More 2801 mods
Curious as to what kind of mod you plan. Inquiring minds...[/QUOTE]
uh oh, those are different. My trailer had a vacuum breaker in line. Just bought one on Amazon. I guess it will be of no use. I was going to replace it with a metal one since I already had a flood in the trailer and heard how unreliable the plastic ones were. Apparently this is a different style in the MH. This is what I ordered:
Old 04-10-2018, 09:28 PM   #410
uh oh, those are different. My trailer had a vacuum breaker in line. Just bought one on Amazon. I guess it will be of no use. I was going to replace it with a metal one since I already had a flood in the trailer and heard how unreliable the plastic ones were. Apparently this is a different style in the MH. This is what I ordered:Attachment 167803
The device Duckogram shows in his pics is a vent for the DRAIN plumbing. The device AbdRahim shows in his pic is a backflow prevention device for a black tank flushing connection.
Although "similar," they are two different devices for basically two different systems.
The first lets air in to assist in drain line draining (similar to the roof vents you see on your house roof). The second prevents black tank water from flowing back into the black water flush connection source.
2011 Traverse LT, 3.6L, FWD
Old 04-10-2018, 09:32 PM   #411
I am looking for this device on the 2801QS.
Old 04-10-2018, 09:42 PM   #412
If you mean the black tank flush anti-siphon valve that you pictured, it is also usually in a bathroom sink cabinet, usually close to your outside black tank flush connection. It should be mounted as in your pic, round head on top, but some folks have reported that the factory installed it sideways (backwards).
It should look like this (this one's a plastic one):
Closeup of the plastic version of the valve:
Old 04-10-2018, 10:10 PM   #413
yup. That plastic one was bad on the trailer and I flooded it on the first trip. I figured I would get a better quality one and either replace the plastic one or keep i.e. on hand just in case. These are up there pretty good. ?I hope there is room for the replacement.
Old 04-11-2018, 07:38 AM   #414
See post #6 here for a PDF on how it should be plumbed, in case you did not know.
http://www.forestriverforums.com/for...ml#post1779085
Old 04-11-2018, 10:22 AM   #415
Ambassador Member
Duckogram's Avatar
Oh, that lil begger. I call it a anti-siphon/check valve. Ours is located in the bathroom, behind the drawer. Its across the cable chase from the auto-transfer switch. Sorry for the confuson.
Plenty of room to get to it.
Ducky
Towing Smart
No PM’s.
Old 04-11-2018, 03:30 PM   #416
Thanks Duckogram. Did not think to look back there. Going to pick it up next week. I will take the drawer out and take a look.
Old 04-11-2018, 04:41 PM   #417
Tombsy's Avatar
Finally got some work done today but the rig is still stuck in the snow at the storage lot. Hopefully I should be able to get it out by the weekend. I put in the coach batteries, and had to replace the chassis battery that didn’t make it through this nasty winter. But the K&N cold air kit installed very nicely, no problems at all and it came really good step by step instructions with photos for every step that matched the rig perfectly.
Brian
Old 04-11-2018, 05:32 PM   #418
Ambassador Member
Duckogram's Avatar
Brian that looks great. Do you have a 5 star strategy loaded? and if so, do you need a new program?
Edit: Just checked K&N’s site and the CAI does not fit the 2017 chassis!
Ducky
Towing Smart
No PM’s.
Old 04-11-2018, 06:49 PM   #419
Tombsy's Avatar
Thanks, I’m thinking the tune will need an update, I have a email to 5 Star to find out my options. It might be worth you giving them a call to find out about the 2017’s, they sell tuners bundled with the intakes but when you follow the link to 2016-2019 K&N’s it shows the same one I have.
Brian
Old 04-11-2018, 07:04 PM   #420
Ambassador Member
Duckogram's Avatar
I cant find that link. The 5 star page that lists all the different options is so you can tell them what you have.
Ducky
Towing Smart
No PM’s.
280, forester, modifications
