Old 05-23-2018, 02:34 PM   #461
Originally Posted by Duckogram View Post
Just saw the news: UFO REPORTED...
AbdRahim is offline   Reply With Quote
Old 05-28-2018, 05:22 PM   #462
sgtlm17's Avatar
I just replaced my noisy water pump with a SeaFlo series 42. Was a simple swap no modifications needed. The SeaFlo is whisper quiet. compared to the Shurflo I had and water pressure is better. Click image for larger version
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-28-2018, 07:20 PM   #463
Ambassador Member
Duckogram's Avatar
Nce work. I like the accumulator in lieu of the filter as well. Good choice.
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Duckogram is online now   Reply With Quote
Old 05-29-2018, 01:42 AM   #464
Originally Posted by Tombsy View Post
The chairs are in, they couldnt have been a better fit. I did have to remove the shelf, but then I had a brainwave, (okay the wife helped lol), that maybe it would fit next to the bed.
Turns out its a perfect fit to clear the bed slide, I trimmed it 32.
Attachment 168623
Attachment 168624
Oh my! Jealous here! Those look so comfy! Where did you get the recliners? They sure would have made our trip through Canada a lot more enjoyable. Where was the shelf located and where in the bedroom did you put it! This sight is so useful with all the suggestions and ideas of what we can do to ours.
Jodi...
Alaskaforester is offline   Reply With Quote
Old 05-29-2018, 08:22 AM   #465
Tombsy's Avatar
Jodi...
Thanks, they are a great improvement over the jack-knife sofa. I got them at the Calgary RV show from Woodys RV but they are a Lippert product, the same supplier Forest River uses. The shelf ran under the window and I cut it down and put it along side of the bed. See post #443.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 05-30-2018, 12:30 PM   #466
Tombsy's Avatar
I want to save Duckogram's pantry latch info where I can find it
http://www.forestriverforums.com/for...ke-161071.html
Good news, we are hopefully closing on a new house this Friday with room for all the toys at home. Sure will make the mods easier
Brian
Old 05-30-2018, 01:15 PM   #467
Ambassador Member
Duckogram's Avatar
I want to save Duckogram's pantry latch info where I can find it...
But its only a mod if you do it. OEM for me.
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 06-01-2018, 10:14 PM   #468
Smile What is the real length of the Forester GTS 2801QS?
The factory calls this a 28 foot coach but brochure says it almost 32 feet long... nowhere does it discuss how long it is with the rear slide extended. All of this is important for me, because I have to keep my coach under 30 feet to park it at my home. If it's only 31 feet long with the bedroom slide extended, but shorter than 30 feet when the bedroom slide is in, I'm good to go.
Richard Loewenhagen is offline   Reply With Quote
Old 06-02-2018, 07:30 AM   #469
Ambassador Member
Duckogram's Avatar
I responded to your new thread however the subject coach will never* be under 30.
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 06-13-2018, 10:59 AM   #470
Tombsy's Avatar
Not sure if its a mod but it will definitely lead to some ...we are moving from our Villa condo to a house nearby with room in the back for our rig. And a big heated garage for my boat and toys. That gets rid of two storage lots and a ton of hassle getting loaded for a trip or working on the rig. A ton of work packing, were moving July 9. Missing a couple fishing trips but it will be so worth it .
Brian
Old 06-13-2018, 03:28 PM   #471
Ambassador Member
Duckogram's Avatar
Best wishes for good health and happiness in your new abode.
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 07-30-2018, 11:28 AM   #472
More 2801 mods
Has anyone installed a shutoff valve for the water supply to the toilet?
There is not much room back there. I finally got the cover off and replaced it with a cover simply held down by two screws (solid wood), giving me easy access to the area behind the toilet. The top piece is stapled on the outer edge on top and screwed in from the sides. It appears as it was put together from underneath. The access to the screws on the right side are inside the cabinet (requires removing the drawer and reaching down to unscrew). The left side, possibly an angle screw from underneath. I ended up tearing the left side off.Click image for larger version
Old 07-30-2018, 02:52 PM   #473
More 2801 mods
The day night shade over the dinette does not fit well and slides down, so I put plexiglass strips along the edges. No more sloppy hanging down. I also painted the outside of the skylight white.
Space behind the toilet closed with real would and easy access
I will screw a piece of trim from the bottom, so that it will look nicer and come off with the top should I ever need to get in there. I also reinforce PDF the vertical piece, as the only thing holding it in place was the staples through the top piece.
Old 09-09-2018, 07:00 PM   #474
Tombsy's Avatar
Well I guess Ive sorta been working on our biggest mod yet, moved out of our villa condo back to a house where we can keep all the toys at home. Our trips for the summer were put on hold but it will be so much easier to work on the rig in the future. Theres a big heated garage with room for my boat and workshop and space for an RV pad next to it.
Had to get some trees cut, stumps removed, 12 yards of grass and dirt replaced with gravel but the pad is done. Now to set the posts for a gate to replace the fence.
Brian
Old 09-09-2018, 07:14 PM   #475
Attachment 185946
To do it right, you need a 16' high pole barn on that pad!
2011 Traverse LT, 3.6L, FWD
Old 09-09-2018, 08:25 PM   #476
DaLexusGuy
LeoS's Avatar
I had my dealer install a tall Dometic 320 with sprayer.
LeoS is offline   Reply With Quote
Old 09-09-2018, 08:34 PM   #477
DaLexusGuy
LeoS's Avatar
Regarding Shelves for the wardrobe closet: There is some silvery/tan looking metal wire shelving available at my local Home Depot (after all, white is so "yesterday"). I bought one long upright support, cut it in half and mounted them side by side (about 1 foot apart) onto the back wall on one-half of the wardrobe. Then I bought one of the matching 4' silvery/tan shelf and it cut it into three 14" sections. I also bought 6 matching shelf supports and mounted them and the shelves onto the supports. Total cost of the project was about $80. DW was extremely impressed (no small feat, that) and said it looks "factory" which I took as an insult at first because I did not install them crooked like they would have. I came to realize that she meant well and I have since forgiven her.
Old 09-09-2018, 08:45 PM   #478
DaLexusGuy
LeoS's Avatar
AbdRahim,
Now that you custom-made your water line access panel behind the toilet, you need to remove that fancy ole' cover and use some expanding spray foam to fill the 2" x 2" hole that is open to the tank drain compartment below. The mice will probably be REALLY bummed out, but you will be glad you did it.
Old 09-10-2018, 06:12 PM   #479
Originally Posted by LeoS View Post
AbdRahim,
Thanks, Leo. I noticed that space. I was wondering why I was feeling air conditioning in the dump valve compartment.Some air flow with heat might be helpful during the colder months. Hopefully no mice will get in. During the summer with air conditioning and ventilation it is tough to keep the peppermint oil and Fresh Cab scents strong, but when it is closed up for the winter, the set scents are potent to humans much less mice. Hopefully that and sealing all access from outside, along with mothballs underneath the unit will keep them out. I even hang some in the engine, propane, and generator compartments.
Old 09-14-2018, 08:02 PM   #480
Anyone have water entering the basement compartments. I had water coming in through the lock and thumb locks and dripping past the gasket. These are new gaskets installed by FR. I silicones around the locks on the door I saw leaking and tested it with a hose. The slide has been out for days and of course it has been raining for days. Today I found water in the long front driver side compartment again and in the fw compartment. Can't figure out how it is getting in. The seal against the gasket feels tight.
280, forester, modifications
