Old 10-10-2007, 09:15 AM   #1
More questions about winterization
Now my new question. My camper will be winterize in two weeks. The engine (E450) V-10 last oil change was done approximately 3 months ago and it probably does have 1500 miles on it. for this winter I am planning to drive the camper once a month to exercise the generator, and probably drive between 10 and 15 miles per month to move the engine/transmission parts. Now should I wait until early Spring to change the oil and filter? or should I change it now and then again next Spring? Thanks.
wengerda is offline   Reply With Quote
Old 10-10-2007, 09:17 AM   #2
RAC
Wait till spring.
RAC is offline   Reply With Quote
Old 10-10-2007, 09:23 AM   #3
Originally Posted by RetiredArmyCWO View Post
Wait till spring.
Dito
aintgotnun is offline   Reply With Quote
Old 10-10-2007, 09:28 AM   #4
RAC
Of course you ditto...GMTA remember?
Old 10-10-2007, 09:34 AM   #5
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I'm no mechanic...but I've always gone with whatever the manufacturer recommends. I'm always afraid of voiding warranties, or simply adding to wear.
In your case, I think it's safe to say you are probably good until Spring. I'm assuming the engine break-in was done according to Owners Manual...and you are operating on clean oil (not break in). If not, I'd change it right away.
A little overkill on oil changing will never hurt...IMHO.
Good luck
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 10-10-2007, 09:57 AM   #6
The vehicle does have 16,400 miles. I purchased it used last few months ago. At the time of purchase, the oil was changed. I hoped that the previous owner did follow the manufacture break-in period. Thanks.
Old 10-10-2007, 10:04 AM   #7
RAC
Did the vehicle come with the service records? if not, was there a sticker on the windshield with the last place service was done, and when the next due is?? Then you can go to that place and they can pull the records for you.
Good Luck!
Old 10-10-2007, 10:12 AM   #8
The Jolly Mon
NDJollyMon's Avatar
by (break in) I meant the oil that came in it originally. My reasoning is that new engines may get some particulate in the oil. No sense taking a chance.
Pete (Jolly Mon)
Old 10-10-2007, 10:26 AM   #9
RAC
Good Luck!
Old 10-10-2007, 10:40 AM   #10
I purchased the vehicle very very far away from home in Danville, VA. No maintenance record, but the oil was changed at the time of the purchase of the camper. I also had the transmission and the differential fluid changed too.
Old 10-10-2007, 10:44 AM   #11
RAC
The person or dealer you bought it from didn't have any records?
Old 10-10-2007, 11:08 AM   #12
Nope
Old 10-10-2007, 09:56 PM   #13
welshman599's Avatar
Send a message via MSN to welshman599
Well you changed the other fluids and I take it the oil looks good & reasonably clear, so unless you are in a northerly climate and want to shift down to a lighter grade for those winter starts, I'd let it go til next spring.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-19-2007, 06:34 AM   #14
My last final question about winterization. I completed the process, and I am very confident that I did everything that it needs to be done to winterize my camper. Now, I received a flyer from Camping World, and their winterization price is $99.00 plus parts. But if you want your water filter winterize it will cost and additional $10.00. What kind of process they have to do to the water filter. In my case, I removed the water filter cartridge prior to winterize the camper. Do I need to do anything else? After completing the winterization process, my water filter empty clear canister was full of antifreeze. I took that antifreeze and emptied it into the traps. Do I need to do anything else in regards to the water filter/canister. Should I have to leave some antifreeze in that clear empty canister? Thanks.
Old 10-19-2007, 01:10 PM   #15
If it's empty there isn't anything to freeze. Leave it empty.
Old 10-19-2007, 03:29 PM   #16
The Jolly Mon
NDJollyMon's Avatar
I left mine full...but you had a good idea using it elsewhere...I never even thought of it. Shouldn't matter either way.
Pete (Jolly Mon)
sunseeker le
