Old 02-28-2018, 03:28 PM   #1
New Motor Home Tires Class C
Have a 3010DS. It came with the Michelins on it, They are aprox 5 years old.
They show a lot of dry rot. Now trying to decide on , another set of Michelins, Have used the Firestone Transforce on that last class C we had and they proved to be very good.
What about the Hancook tire, See that Ford is putting them on the E450 from the factory, Any one have any experiecnce with the Hancooks.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 02-28-2018, 03:44 PM   #2
Certified Curmudgeon
Duckogram's Avatar
I have the Hankooks but have not driven on anything but dry flat roads. I would estimate by the ratings they got in TireRack that they are OK but do not measure up to Michelin quality. If they offer no confidence in wet, they will be gone in a flash. TBD
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
Old 02-28-2018, 04:12 PM   #3
Have a friend with a class C that bought Continental tires because the load rating was higher.
Reverse_snowbird is offline   Reply With Quote
Old 02-28-2018, 04:26 PM   #4
On my old class C I ran Hankook tires on it and they performed very well in both wet and dry conditions .
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-28-2018, 07:53 PM   #5
RedLdr1's Avatar
I have Hankooks on our Ford Transit based motor home and on my F-150. When it is time for new tires they won't be Hankooks. They just do not "feel" as good as the Michelins I've previously used. The Hankooks on my F-150 break traction way too easy, I feel like a 16 year old doing burnouts at times...
You might want to take a look at joining the FMCA for their tire discount programs and other benefits. See Here for more information.
Wayne
2022 R-Pod RP-192
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, 7.2KW Pro Power, 1,840# Cargo, 7,000# Tow
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
Old 03-01-2018, 09:19 AM   #6
Was just trying to get info on other tires, Thanks for the input. Think im just going to stick with what it had and go with the Michelins.
Old 03-01-2018, 10:21 AM   #7
New units seem to be coming w/ General Tire Grabbers, from what I can remember seeing on the lots recently.
2019 Jayco Greyhawk 29MV
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
s1njin is offline   Reply With Quote
Old 03-01-2018, 10:58 AM   #8
I switched to the defender ltx more stable
Stronger side wall.
Fisher72 is offline   Reply With Quote
Old 03-01-2018, 11:05 AM   #9
Is the Defender LTX a Michelin ?
Old 03-01-2018, 11:09 AM   #10
Yes.
Old 03-01-2018, 01:49 PM   #11
There has been a recall on Michellins for dry rotting
Worth checking into. I ended up with a new set several years ago for this very reason.
Recommend to go with the heaviest load rating you can get. Most tires put on RV's at the factory do not take into consideration what we load into an RV (other than ourselves).
YoBobH42 is offline   Reply With Quote
Old 03-01-2018, 01:52 PM   #12
Yes correct ...
Old 03-01-2018, 01:54 PM   #13
Yes Michelin less road noise as well ...
Old 03-01-2018, 02:20 PM   #14
I would only put Michelins on an RV I was planning to park in a salvage yard.
The Michelin RV rated tires I had on my previous motor home were bad from the factory, as were many Michelin RV rated tires at that time. Read lots of reviews and others were having the same issues.
Michelin may have corrected their issues, but they would not admit to bad tires at the time.
Due to three out of 6 NEW Michelin tires blowing sidewalls in 12 months, I'll never buy Michelin again. Ever.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 03-01-2018, 02:22 PM   #15
Michelin Defender LTX X2
Smooth riding and never use any other tires including on my cars. I don't think that you can beat them.
Bob Brown
_______________________
2013 Forest River Sunseeker 3170 DS
bobbrown is offline   Reply With Quote
Old 03-01-2018, 02:24 PM   #16
Any on know the difference between the LTX M/S and the LTX M/S2 ??
Or have used the M/S 2 ?
Old 03-01-2018, 02:34 PM   #17
I can't speak to travel trailers but as far as motorhomes are concerned, they have to put tires on the rig that match the axle capacity of the rig. So you'll typically see Load 'E' tires on the Chevy/Ford chassis models. The OEM tires are good up to the max axle weights, though admittedlly right up at max PSI depending on the length/weight of the coach.
My 32' Greyhawk was Load 'E' 75 front, 80 rear. My soon to be 25' Forester is 65 front, 80 rear.
Load E tires max out at 80psi.
Old 03-01-2018, 02:57 PM   #18
When I talked with Michelin about my M/S
LTX wearing down 4/32 in less than 4,000
Miles also had cupping on front and rear
And I had the forest river suggested alignment ( I went with Henderson Line up specs ) he told me the M/S ltx is not the best fit for motorhome application . He said
The side walls are soft and they will get fold over issues . He advised me strongly to proceed to the defender LTX .
Old 03-01-2018, 03:09 PM   #19
From what i have found. The Defender LTX M/S is what replaced the Regular LTX M/S
Old 03-01-2018, 03:36 PM   #20
From Tirerack:
"Compared to the popular Michelin LTX M/S2 it replaces, the new Defender LTX M/S tires share the same highly functional tread pattern, and offer improvements in wear life/longevity to better meet the high-torque demands of modern trucks. Defender LTX M/S is designed to be stronger, longer."
I have LTX M/S2's on my 32 foot Sunseeker with about 25K miles, and they're ready to be replaced. The rears wore evenly (which I would expect), but the fronts did something weird...the treadblocks on either side of the center rib are OK, but the center rib and outboard treadblocks all got very choppy. Alignment is good and the wear is even across the whole tire, just weird. I rotated them to the back to try and get some more life out to them, but the rumble is noticeable enough that I'll be replacing all six before we make the trek from NJ to Disney for Spring Break.
Will go for either the Defender LTX (hopefully this re-design takes care of that "weird" wear I experienced) or Firestone Transforce HT...had a set of those on my last C-class and was very happy them.
rad_jr is offline   Reply With Quote
class c, tire, tires
