[QUOTE=Poolboy;1908565]Hi, I'm a new owner of a 2004 Sunseeker 2860DS and have a bunch of questions.
1. The shore power cord is in a compartment in the basement. To have it hooked up the cord needs to hang out of the compartment which leaves the door cracked open and open to rain...am I missing something?
Our Solera has a cord pass-through like this:
https://www.amazon.com/JR-Products-S...cord+pass+thru
If your Sunseeker doesn’t have one, looks pretty easy to install with a hole saw.
2. My outlets only work on the generator. They trip my home gfi when plugged into the 110 converter plug then plugged into house thru extension cord.
Lots of issues trying to hook up to a gfi circuit. Most use a non-gfi home circuit.
3. Where can I find body parts? I need a little piece of trim that goes over the rear drivers side tire.
Lots of generic parts are available on Amazon. Probably also on e-bay (I don’t use e-bay nearly as much). Example:
https://www.amazon.com/ICON-12038-Ic...v+fender+skirt
4. No idea on wireless bu cameras.
