Originally Posted by Susan.B
Hello! We just bought a used 2018 Sunseeker 2860do. We just got it Wednesday & took it out for a shakedown trip. We have several things we need to figure out, organize, modify. I’d love any great tips or modifications. We are weekend campers & have had a pop-up, TT, & then FR Wildcat 5th wheel but it has been a few yrs. This is my list so far:
*I hate how the entrance door won’t close unless we pull out the handle.
*Need to install shelving in bdrm closet. I’m wondering if back wall is strong enough to hold metal strips for adjustable wire shelves.
*I can’t figure out how the cab curtain is supposed to go. We attached to velcro dots but we had tons of extra fabrics and extra dot. Anyone have a picture or diagram how it is supposed to go?
* The Ac was not keeping it cool at all. Air coming out today was 65 but yesterday was even warmer. It seems there is cool air going into one of the compartments and outside kitchen. Why is that & how can we stop it?
*Inside & outside fridge both seem to be not cooling enough.
*The couch, dinette & cab seats are all a vinyl that will not hold up great with dogs. We want to cover them, do you know of places that sell covers so I don’t have to try making them?
*The wood “wallpaper” on Bathroom door & bdrm valance are peeling. Can that be redone?
Thanks for any help! We are excited to get back into RVing. I can’t wait to decorate & customize a little more & add some color.
Ok, you can try to adjust the strike plate but it moves very little, lube the door side of the latch to make sure it moves freely.
You can put in shelves but watch the weight. We have the Forester version of your unit and use plastic drawers that slide right into the space, don’t move and are easily removed if we need the space.
Cab curtain wraps into the curved are over the cab, it doesn’t go straight across. However I would pick up an outside class C window cover, works better, cuts down on the heat and leaves easy access to the front cab for storage.
Pull down the filter screen on the AC. Make sure it’s clean. A clogged filter will cause loss of cooling. While it’s down make sure the diverter/return is in place, sometimes it comes loose or shifts creating loss of cooling. Check the temp coming right out of the unit, then close the damper and check air flow at the other vents. Should be fairly even with the most air pushing out the vents closer to the unit. Depending on the temp the single unit can struggle to keep everything cool, we had a similar issue on our 2017. We would close the blinds, use the cab cover and supplemental fans in the unit to help keep it cool when it was hot.
A good upholsterer should be able to recover you cushion. Check locally for car accessory shops, many do custom work and they should be able to direct you to someone.
Some wall paper seam sealer or wallpaper paste/elmers glue should re secure the loose wallpaper provided it’s not torn, it is possible to paper over it too with the proper primer.
