Old 11-09-2014, 01:28 PM   #1
rsscully's Avatar
Onan generator hour meter.
My generator has very low hours on it, maybe 30. The last two times I have run it the hour meter has not worked. The hour meter does not show anything anymore. Pulled the panel and have ~12 volts on either side of the meter when not running. When I have the genny running I only have ~12 volts on one side of the meter. Is this normal? Any ideas? Is the meter just bad?
rsscully is offline   Reply With Quote
Old 11-09-2014, 03:37 PM   #2
On side should be positive..other side ground.. You should only have 12 volts when gen set is running...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-09-2014, 03:40 PM   #3
This may help..
http://www.justanswer.com/small-engi...eter-does.html
Old 11-09-2014, 04:32 PM   #4
rsscully's Avatar
Thanks Jester. I actually read that already. The light works, the terminals have voltage but no display.
Old 11-09-2014, 04:58 PM   #5
Is your gauge analog or digital?
Old 11-09-2014, 05:08 PM   #6
rsscully's Avatar
Digital.
T44 Series LCD Hourmeter, EEPROM Memory On ENM Company
Old 11-09-2014, 05:13 PM   #7
What I find strange is you have 12 volts on both sides... I don't believe you should have any power to the gauge unless unit is running....
Old 11-09-2014, 05:26 PM   #8
Do you have a hr meter on gen set it self... Is the dc fuse intact?
Old 11-09-2014, 08:04 PM   #9
It's possible that starting the generator applies a ground to the negative side of the meter. If that is the case you would read 12V on both sides when the generator is not running. I think you have a bad meter.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is offline   Reply With Quote
Old 11-09-2014, 09:36 PM   #10
x2 on a bad meter.
ATVer is offline   Reply With Quote
Old 11-09-2014, 10:07 PM   #11
if you have a ky generator you are under warranty take it to an onan or cummings repair shop. they will fix it .warranty is three years or one thousand hours
oldnewguy is offline   Reply With Quote
generator
