05-27-2022, 10:52 AM
One control voltage display
Greetings:
On my one control app , the voltage displayed has gone blank.
I did have the voltage displayed and now it is just dashed lines?
Is there any solution?
Thank You;
Brian French
2019 3011DS
05-27-2022, 12:01 PM
Originally Posted by Brianfrench65
Greetings:
Thank You;
Brian French
2019 3011DS
I know my app was recently updated. I never had the DC volts before. Now I do.
Lippert Tech Support has been very good in responding to my questions. Probably your best best.
Good Luck.
05-27-2022, 12:19 PM
It might have been hiding. I was (pleasantly) surprised to find it in the header, up near the top on the right, right below the *warnings* and *settings* icons.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
05-27-2022, 12:35 PM
You are probably correct. I rarely used it except to put the Awning down at home when the wind would pick up or rain started. And i did not want to get wet. haha
05-27-2022, 02:08 PM
Pretty much the same. Due to bad planning on my part, I have all my solar and battery displays hidden with the slide in. I discovered the power display in OneControl by happy accident!
05-27-2022, 02:13 PM
Sometimes it is better to be lucky than to be good.......
05-27-2022, 03:22 PM
Absolutely!
It was actually a planned decision, I just didn't think it all the way through. I was initially going to install a second, bluetooth-enabled monitor in my solar control bay that I would be able to see without even opening the trailer (just popping one of the small cargo pass through hatches), but - with the phone - didn't have to go to the expense!
05-28-2022, 07:22 AM
Thank You All for your input and suggestions.
I will have to call for some support and. Instructions on Tuesday.
Thank You;
Brian French
2019 3011DS
05-28-2022, 09:49 AM
Thank You;
Brian French
2019 3011DS
Your welcome.
Of course the first thing they may ask you to do is reinstall the app. Have you tried that?
05-28-2022, 01:49 PM
Well….I just deleted the app and went to the App Store and reinstalled the app.
The voltage did display only until I got out of the app to do something in my email.
When I went back into the app, everything was there EXCEPT THE VOLTAGE????
Thank You For A Great Suggestion;
Brian French
2019 3011DS
05-28-2022, 03:35 PM
Brian French
2019 3011DS
Welcome, now that is a cumbersome way to make it work
I imagine that may give Lippert a clue as to why.
Good luck.
