Originally Posted by Forester1966
On my 2017 Forester 2861DS, Finding the hot water tank shut off, I found three shutoff valves, one on the blue line (open position), one on the red line (open), and one that connects the blue line with the red line (closed). I assume this is the shutoff valve and just open the valve. So for by-pass of the hot water tank just open the valve. My question is then, do I close the other valves to complete the shutoff procedure?
Underneath tied to the blue drain line (from the freshwater tank) is a red line that is capped. This must be a drain from the hot water tank. So I drained that line too. Thanks for the info on the water filter.
Yes - close both the blue line valve and red line valve so water/antifreeze cannot pass into the HW tank. The valve in the middle is your bypass valve - open that one as you presumed above. The red line that is capped under the camper is not the HW tank drain - it is more likely a low point drain of your hot water lines. To drain the HW tank (if it is a Suburban) use a 1-1/16 socket to pull the anode rod out near the bottom of the tank (outside)
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
