Old 10-07-2017, 12:54 PM   #1
Outside TV sound through Solera awning speakers
Is there a way to channel the sound from the outside TV through the Jensen unit to the awning speakers?
GMax is offline   Reply With Quote
Old 10-09-2017, 12:39 AM   #2
Kirk S's Avatar
Following.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 10-09-2017, 08:36 AM   #3
jeff64's Avatar
Got 2 TVs? Can you make the inside one play through your outside speakers? Do it and watch the outside video. I have to turn the outside volume down or I get a reverb effect. That's what I have to do with the iRV66
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
jeff64 is online now   Reply With Quote
Old 10-09-2017, 08:46 AM   #4
Flybob's Avatar
If the outside tv has a headphone jack, You have couple of options One above or.
1. Run a 3 conductor shielded cable from the headphone jack to the aux in on the stereo.
2.Get a bluetooth transmitter and pair it with the sound system. Connect the bluetooth transmitter to the tv via a 1/8 stereo plug. This solution is much simpler, but depending on the BT transmitter design, could result in a delay between the actual audio and the video. This means sound will be out of sync with lips. Not an issue if watching sports, but can be annoying for movies.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-09-2017, 09:05 AM   #5
Yes to question # 1. Have not tried the video idea, yet. Thanks for the suggestion.
awning, solera
