Old 10-11-2015, 12:53 PM   #1
rbetzwieser's Avatar
Overhead Cab TV in 3050s
So show of hands, who also hates the location of the main TV in their Sunseeker?
rbetzwieser is offline   Reply With Quote
Old 10-11-2015, 04:02 PM   #2
JimOneil43's Avatar
We have been planning to buy a 3051S and noticed that the TV viewing angle is awkward from the sofa also. When we get our MH, I plan to see if we can re-locate the TV on a flip-up bracket mounted above the dinette, which would be directly across from the sofa. Not sure if it will work until we get our MH and try it. Amazon and other sites show quite a variety of TV mounting brackets. I would even sacrifice one of the cabinets over the dinette to mount it to.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 10-11-2015, 04:22 PM   #3
Awkward angle is an understatement. I actually just relocated it to the dinette table. I found a stand online for that Jensen TV. I just unplug it put it in the cab over area when we travel. FYI to do this you need to run 6 cables to the dinette and plug the 12 volt in under the dinette. The 2 pictures I attached show the 6 cables being run from the cab area to the back of the dinette. I bundled the cables and left enough slack so they move with the slide. I then ran the cables under the seat of the dinette and up the back of the table through the cupholder hole to the TV.
ID:	91239   Click image for larger version
Old 10-11-2015, 05:36 PM   #4
2SGMRET's Avatar
I purchased a new mount that has the ability to move (rotate) in front of the cabinets above the dinette. Mounted it in the same location. So much better.
2SGMRET is offline   Reply With Quote
Old 10-11-2015, 05:46 PM   #5
Do you have a picture or a link to the mount?
Old 10-11-2015, 09:04 PM   #6
2SGMRET's Avatar
Name:	ImageUploadedByForest River Forums1444615406.366176.jpg
ID:	91270. Purchased at Costco. Also purchased a TV earthquake strap from Home Depot to secure while traveling.
Old 10-13-2015, 08:49 PM   #7
Mike968's Avatar
I've got my hand up.
It's a crappy afterthought, seriously I thought it was a poorly executed dealer option...but no, they actually do that on purpose!
Mike968 is offline   Reply With Quote
Old 10-14-2015, 08:48 AM   #8
TV in 3050s
I cut the long arm into 3 pieces and installed 2 hinges so it swings around then swings back against the slide wall. making viewing almost straight across from the front end of the couch.
2015 Sunseeker 3050s
15 Years Full Timing
Now own Sticks and Bricks
J. V. is offline   Reply With Quote
Old 10-14-2015, 12:14 PM   #9
JimOneil43's Avatar
JV, do you have a picture that shows it in it's extended position? This may be the fix we were looking for.
Born April 18, 2016
GO DUCKS !!
305, 3050s
