I find it hard to believe that a 2017 CAT system has failed already. A number of things need to be checked before pulling the trigger on new CAT. Easy enough to rule out bad CATS. Run the engine for 10 minutes and get it up to operating temperature, then climb underneath with an infrared thermometer. Shoot the inlet of the CAT, record the temp. Then shoot the outlet of the CAT and record that temp. Do this for both CATs. Compare the two readings. The outlet temp should be at least 100 degrees warmer than the inlet temperature. If so, the CATs are fine and your problem is somewhere else. For further diagnosis you will need a scan tool to take a look at the freeze frame data stored with the code. It will give you a picture of all sensor readings when the code was set. Also, take a look at the upstream vs. downstream O2 sensors. The upstream should be low mV and switch constantly RICH-LEAN-RICH-LEAN etc. The downstream should be high in mV and constant. Fuel trim should also be checked.
2016 Salem 27RKSS
