Originally Posted by Chigbot
Already had the old ones (2017 date) tested and I replaced them with group 27 AGM’s. Per this forum the stock inverter is ok when upgrading to AGM’s!
when did you replace them.... Your first post sounds like you still have the OLD ones in place?
Inverter / charger could be installed
it automatically detects is shore power is available ... if yes, it charges the battery
if no shore power connected it goes into Inverter mode and makes 120v
while not in use.... you do not want to leave it turned "ON" and powering things such as the fridge or water heater using Inverter MODE the batteries will drain quiet fast
Check you user guide on how to store the RV
no guessing involved.
test battery voltage using multi meter at the battery posts
best to disconnect the positive cable from the battery so no outside power source can interfere with your reading
To test if battery is drawing a parasitic load...
use multi meter set to read amps
