Old 04-18-2013, 01:43 PM   #1
Power step not working STUCK OUT!!!
2004 SS 3100
I stored my RV with the step out, now it will not shut once all power is on & rv running. It did this to me a 4 months ago but then started to work again. when I started it up a month ago it worked. Its like it got stuck out. Is there something I can grease or bang on to help it out. Maybe motor is bad or something. Is there a manual close option? Any help would be much appriciated.
fmf421 is offline   Reply With Quote
Old 04-18-2013, 02:17 PM   #2
Commercial Member
I would use liquid wrench on ALL the moving parts underneath. Those things have a tendency to rust.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-18-2013, 02:59 PM   #3
This happened to me and the board went bad. The boards are expensive but easy to diagnose if you can remove the the 3 bolts and 2 plugs. There is a hot , ground, door switch and ignition wire. My door switch lead would not wotk because of bad board. Just run a 12v to hot and ground. Then jump to door switch.
bigdog1001 is offline   Reply With Quote
