04-12-2017, 12:17 PM
Propane appliances not working
Hi all
I have a full tank of propane but none of the appliances are working I have no idea how to fix it can anyone help me.
I tried to light the stove and that won't work.
Then I tried the water heater and that won't light either.
The refrigerator is not working on Gas.
I am new to the RV world. this is my first RV. I have a 3051 any advice would be much appreciated.
thank you
04-12-2017, 12:25 PM
Originally Posted by jackpaulg
Hi all
thank you
Howdy and welcome aboard. The easiest and most obvious thing to check, is to make sure you have the propane cylinder(s) valve open. It's open when you unscrew it (left turns) and closed or shut off when you screw it right all the way.
I would recommend closing it first all the way (clockwise turns)...then s-l-o-w-l-y opening it (counterclockwise) all the way.
 2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
04-12-2017, 12:26 PM
Turn off your propane tank. Disconnect the hose from the tank. Reconnect the hose to the tank, then turn the propane tank back on very slowly. Very slowly. Now go to your stove and see if you have propane.
Bruce
04-12-2017, 12:52 PM
OK sounds good thanks Bruce I appreciate the advice were in Disneyland and it's a bit of an inconvenience thanks for your response
04-12-2017, 01:01 PM
Did anything ever work on propane or is this a new issue?
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=15
04-12-2017, 02:15 PM
It is a new issue. it was working when we left in the morning and then when I came back later that day I noticed the fridge was not working
04-12-2017, 09:02 PM
Your regulator may have failed. Since you are new to RV's, it may not be a good idea to start loosening gas lines to figure it out, so if none of the suggestions you get here help, you may have to have a qualified technician fix it.
If you are a do-it-yourselfer, go to an RV store and buy a propane regulator. They aren't expensive. It would be worth trying it before hiring a technician. Even if your coach is under warranty, it could take days before a shop can get to it.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
04-12-2017, 09:08 PM
yeah I just tried to get it going doing what was suggested above and nothing I do seems to be working.
Thank you for the reply.
04-12-2017, 09:16 PM
If you decide to get one, be sure it's a.two stage regulator for an RV, not a single stage one for a grill. Also, be sure it's made to mount with the inlet and outlet horizontal and with the vent in the right direction. It won't work right if it's not installed in the orientation it's designed for.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
04-12-2017, 09:17 PM
Just trying to stay with the simple first, when did you fill the propane cylinder?
It could just simply be out.
04-12-2017, 09:19 PM
Filled it up on Saturday. And we really haven't used much propane. The gauge on the tank says it still full
04-12-2017, 09:27 PM
Some motorhomes have an electrically operated solenoid valve on the permanently mounted propane tank line. They are sometimes controlled by the propane detector.
Do you know, does your Forester have one?
04-12-2017, 09:28 PM
To be sure you have propane, you could open the bleeder valve. Wear good gloves, preferably leather, and eye protection.
Here's a link to a Web page that shows the bleeder valve.
http://roadtreking.com/innards-rv-propane-tank/
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
04-12-2017, 09:36 PM
Thanks for the response. As with all troubleshooting, it's best to start with the easy stuff first and then work your way up.
04-13-2017, 02:54 AM
Bruce
Bruce,
Why slowly?
Charlie
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
04-13-2017, 12:58 PM
All of the suggestions here are good, but jackpaulg said he has a 3051. If his 3051 is the same as mine, it is a motorhome with a horizontally mounted tank, not a travel trailer where you can just disconnect/reconnect hoses.
The reason for turning any propane tank valve slowly is to prevent the automatic shutoff built into the tank from operating.
The only reasons there would be no propane flow are empty tank (faulty gauge), valve failure (unlikely), regulator failure or safety shutoff has activated due to defect or high gas flow detection.
Kirk
2017 Forester 3051S
04-13-2017, 01:14 PM
Bruce
DITTO. That OPD valve is a safety devise to shut off flow when they top it off and shut off if ypu say tear a line open. And note that if you disconnect the tank then open the valve, without back pressure it will immediately shut down.
I also found that when my tanks were brand new, one would not even fill until we knocked around to loosen the valve safety.
04-13-2017, 01:33 PM
I had the same problem with our trailer one time. The pigtail connector? from the tank to the regulator had collapsed internally and needed to be replaced. Switched to the other tank and was able to heat and cook again. Eventually had to replace the other one as well.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
04-13-2017, 01:38 PM
Had issue a few weeks ago where one tank would not deliver propane on the curb side. Replaced regulator on that side and that did not help. I have a 2-stage regulator that receives propane from both tanks. On the curb side there is a separate regulator. I found that the check valve was seized up and blocked flow. Amazon has the; Camco 59954 1/4" Male NPT x 1/4" Female Propane Fitting Inverted Flare with Check Valve.
Keep us posted.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
04-13-2017, 01:55 PM
If you just filled the tanks, it could be the safety valve as mentioned above. When you remove a tank to fill it, the pressure in the lines is released. When you reconnect the filled tank and turn it on with empty lines, a large volume of propane leaves the tank, This can sometimes fool the safety valve into thinking that there is an open valve and it will shut off. The only way to reset it is to turn the tank off, release the pressure in the lines, wait a few minutes then turn on the valve very slowly until you hear propane flow. Let it sit for a minute or two until the lines pressurize, then you can open fully at any speed,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
