Old 04-24-2015, 06:54 PM   #21
Originally Posted by Trail blazer View Post
I agree, but what I have described above is taking place. So, what's up?
Got me, I don't have a clue.
Old 04-24-2015, 06:54 PM   #22
It is a grill that uses the one pound bottles. But the dealer said it has a regulator, so therefore the supply hose to the grill needs to run to the grill before the coaches regulator.
Trail blazer is offline   Reply With Quote
Old 04-24-2015, 07:04 PM   #23
next question, Is the pic of your propane tank taken as a side view or from the top down. If it is a side view, the tank in upside down. The valve should not be at the bottom of the tank.
cgotto1204 is offline   Reply With Quote
Old 04-24-2015, 07:07 PM   #24
I would say because the flow rate of the rv regulator is higher than the portable grill and there is less restrictions going to the rv burner all the propane is going to stove burner and bypassing grill, reason its going out.Sounds good to me
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-24-2015, 07:14 PM   #25
Anything would sound good to you about now!
SkipnTerri is offline   Reply With Quote
Old 04-24-2015, 07:16 PM   #26
One quick thing to check. Is the valve on the rv propane tank fully open?
You are plumbed correctly. It sounds like a volume/ gas flow issue.
I have a 3010 ds with the factory installed grill quick connect which is installed after the rv regulator. It's not an apples to apples comparison since I don't use a separate grill regulator in my case. But, I am able to run all propane devices inside at the same time as the grill.
jrwalkerpa1 is offline   Reply With Quote
Old 04-24-2015, 07:18 PM   #27
You think????number five
2014 Forester 3051s
2012 Sonic toad
Old 04-24-2015, 07:19 PM   #28
That is what I have. The hose goes to the grill before the coaches regulator. I am stumped!
Old 04-24-2015, 07:21 PM   #29
Yes the valve is open all the way.
Old 04-24-2015, 07:22 PM   #30
The picture is a side view.
Old 04-24-2015, 07:24 PM   #31
It is a side view from left to right. The supply valve from the tank is first, then the tee to the grill, then onward to the two regulators for the coach is next.
Old 04-24-2015, 07:35 PM   #32
OK. From the pics and the info you gave me, it appears that the propane tank may be mounted wrong. The valve should be mount near the top of the tank to allow the liquid propane to expand to pressurized gas. With the valve located at the bottom, it is filled with liquid propane and there isn't enough room for the propane gas to expand to pressure.
Old 04-24-2015, 07:37 PM   #33
It's a motor home and from what I've seen of them, they are usually mounted that way.
Old 04-24-2015, 07:41 PM   #34
Tank is mounted correct! If you were to look at the tank from the end, valve will be at the three o'clock position ( on the side) its a horizontal mounted tank.
2014 Forester 3051s
2012 Sonic toad
Old 04-24-2015, 07:52 PM   #35
Speaking from experience calibrating and repairing pressurized gas lines and gages, the tanks appear to be mounted wrong. The tanks have two mounting brackets, depending if they are attached to the left or right side of the unit. The tank needs to be rotated 90 degrees so that the valve is near the top of the tank.
If you want a visual demonstration, take a can of air duster spray sold in any electronics department. Upright, pressurized air comes out of the nozzle. Upside down, pressurized liquid that is cold enough to chill a beer comes out of the nozzle. Same philosophy with propane systems.
Old 04-24-2015, 07:59 PM   #36
Well cgotto1204, there are thousands and thousands of propane tanks in motorhomes that are mounted wrong then.
Old 04-24-2015, 08:04 PM   #37
Broadway Joe's Avatar
That's why there are two regulators. A high pressure and low pressure.
Broadway Joe is offline   Reply With Quote
Old 04-24-2015, 08:08 PM   #38
??? I only have one regulator on each tank.
Old 04-24-2015, 08:19 PM   #39
Canadian Member
cgotto1204, in this video you will see how Trail blazer's tank is setup. The valve comes out the side of the tank.
Old 04-24-2015, 08:26 PM   #40
OldCoot, I understand what you are saying. I will admit that my experience is mainly with vertical tanks, and if we received a horizontal tank for calibration, we always tested them with the valves at the top of the tank so that we wouldn't be frost burned if there was a hose breach.
propane
