Any two stage regulator will work. Many are rater for vertical or horizontal mounting. You need horizontal, the only difference between them is the position of the vent.
On the one you have you will see the vent is pointing down, that is the correct orientation. You most likely will either need to reuse the POL fitting to the tank or purchase one separately.
FYI the POL fitting that goes on to the tank valve is a left hand thread.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
