Originally Posted by Ford Idaho
How do you keep the steering wheel straight?
The steering wheel has to be unlocked to tow 4 down not locked.. that way it turns and follows the RV. it tracks straight on its own..
That the reason some add the Batt cut off switch. the steps I have to take now is once the Jeep is in place and hooked up I have to turn the key to run, put the main transmission into neutral, put the transfer case in neutral, make sure the park brake is not set, get out, open the hood and turn off the batt switch... drive on..
