Old 09-17-2018, 12:31 PM   #1
soulman327's Avatar
quick questions
We're picking up our 2012 3170Ds this Friday and have 3 quick questions. I have to enlarge the camper shed and want to make sure I make it big enough.
1. Specs say this is 32' 3". Is that rear bumper to front bumper?
2. Specs say it is 11' 3" to the top of the A/C unit. Is the top of the ladder less in height than that?
3. Looked at the roof but have forgotten. Is it flat or sloped from the middle?
Thanks!
John
"If I was any better, I'd be dead!"
"The sun's always shining, otherwise it would be dark!"
"God looks out for the stupid, so I keep Him pretty busy!"
2012 Forest River Sunseeker 3170 DS 32' w/2 slides
soulman327 is offline   Reply With Quote
Old 09-17-2018, 12:37 PM   #2
Shredder's Avatar
It would be flat but regadless if its flat or sloped the clearance is 11'3 so that will be the higest point on your unit and yes the ladder is below that height.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 09-17-2018, 12:48 PM   #3
John
Don't trust the specs. If you can, measure it yourself. Sometimes the specs don't include things like air conditioners, antennae, bumpers or side mirrors.
The specs might have been good for the original unit, but you have no idea what's been added since 2012.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-17-2018, 03:09 PM   #4
soulman327's Avatar
That's the problem and why I'm asking. I would if I could but I'm working 6 hours away and have about 2 days to convert the trade in back to original and enlarge the shed. So I have no way of measuring. My plan is to make the door height 12' and extend the length to 34'. I'm hoping that will be sufficient.
Old 09-17-2018, 03:16 PM   #5
Mr. Dan's Avatar
I don't have the same unit BUT my Wildcat brochure lists the height of my trailer as 12' 6" --- however, it is about 13'3" by actual measurement. I'd say that's about the height of a Dometic 13.5K air conditioner unit.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 64; booked = 30
Old 09-17-2018, 03:23 PM   #6
clr
The height would be the number I would worry about the most. You should be OK with 12 feet I would say. Many units are off a couple of inches or so from spec. but with 12 foot you should still be OK. No RV is allow to be more than 11 feet 6 inch by most DOT rules.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-17-2018, 03:39 PM   #7
Mr. Dan's Avatar
Are you sure? Maybe 13'6" Mine is 13'3". My published brochure height is 12'6".
Old 09-17-2018, 03:52 PM   #8
Yeah, better confirm that. Lots of A classes and 5 th. wheels are 12 ft. and even taller. Tiftin A classes are 12'10" tall.
ActionJackson is offline   Reply With Quote
Old 09-17-2018, 04:03 PM   #9
Iwannacamp's Avatar
It also depends on the tow vehicle(mostly 5er aps). Angle of entrance to shop...
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 09-17-2018, 09:17 PM   #10
clr
OK my bad, I miss typed it is 13 feet 6 inches max height in almost all of the States. I did check my home state Illinois and it is 13-6. My bad or I had a senior moment.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 09-17-2018, 09:19 PM   #11
Mr. Dan's Avatar
No harm. We appreciate your returning with new data.
Old 09-18-2018, 06:19 PM   #12
soulman327's Avatar
Thanks, as usual, for the great help. I ended up calling the dealer and they went out and measured it for me.
Old 09-18-2018, 06:25 PM   #13
...far N Georgia!
formerFR's Avatar
well, let's HOPE that your 'hoping' will work - as we all know the old saying:
Measure TWICE and build once!
Even if we could all 'tell you' what you are wanting to know, it's your building - I wouldn't do anything other than wait until you can physically measure it - OR, use a 16' x 40' building design.
formerFR is offline   Reply With Quote
Old 09-18-2018, 08:37 PM   #14
I'm curious.... Did their measurements agree with the published specs?
Enjoy your 2012 3170D!
Old 09-19-2018, 07:02 PM   #15
soulman327's Avatar
Yes they did!
Old 09-19-2018, 11:47 PM   #16
Yes they did!
Amazing.
Old 09-20-2018, 08:10 AM   #17
Head Rambler
I'm about to ruffle ole duck's feathers, being a member of the cabal! Having owned everything from a 2 person pup tent, up, maybe I'm qualified to answer a general question.
You may have already made all the changes to the cover you intend to make, but if you haven't it may be wise to over-build it some. You've already moved up once and the next RV in your future may be a big ole honking Class A or you may become a member of the cabal and get one of them 5er things. I'd go ahead and make the cover with a clearance of 14' and at least 36' long. That way whatever you get next will fit. (barring one of them 40' monsters!)
Gotta go campin!
Old 09-20-2018, 05:45 PM   #18
soulman327's Avatar
Too late! I've already moved up 4 times and, as a result, had to enlarge the shed 4 times. I am out of room after this latest remodel. Plus I'm too old for this s@*t! I am done!
