Old 01-11-2018, 11:51 PM   #1
fliper74's Avatar
Rain gutter problems 2860DS
Draining water from the gutter will drain right onto the interior door arm rest, right where the power window and lock switch are, when door is fully open. I am a big guy and cannot squeeze into the cab unless door is opened all the way. Any suggestions to correct this problem would be greatly appreciated.Click image for larger version
fliper74 is offline   Reply With Quote
Old 01-12-2018, 09:50 PM   #2
Garrette's Avatar
They all will get you wet. No one that I know of has come up with a good solution. When traveling, we will extend the awning about 2' and exit the coach.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 01-12-2018, 11:00 PM   #3
KayleysMom's Avatar
Same as Garrette: we enter and exit through the coach door.
2017 Forester 2861DS
Chevy Chassis
KayleysMom is offline   Reply With Quote
Old 01-13-2018, 03:32 PM   #4
RedLdr1's Avatar
I looked at how to resolve the "cab door shower" on our previous Class C. It looked like I could remove the drains and reinstall them behind the cab doors. Blocking off the original location of the drain will be the trickiest part I suspect...
Wayne
2022 R-Pod RP-192
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, 7.2KW Pro Power, 1,840# Cargo, 7,000# Tow
It is better to have too much truck than to have too much trailer.
RedLdr1 is offline   Reply With Quote
Old 01-13-2018, 04:23 PM   #5
Platokidd's Avatar
When I first read fliper74 post the other day I ponder the same thing.
Just don't know the best way to fab it. My gutters always get clogged on my tt. No such luck on a c class going down the road that gutter would be clogged
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 01-13-2018, 04:28 PM   #6
remove the gutter.
Old 01-13-2018, 05:32 PM   #7
RedLdr1's Avatar
Originally Posted by cavie View Post
remove the gutter.
I looked at doing that but there are a couple issues with that solution. First, it will leave a mess where it is removed...especially if you have full body paint. Second, if you are parked nose down you could get a much larger shower area than with the current drain.
I was going to partially fill the front section of gutter with Dicor, tapering towards the rear of the coach, to force the water back towards the new drain location. Some water might get out at the old location but it would be better than the current full blast shower...
Instead I "fixed" the issue when we downsized to a smaller coach... Our TS has the "trekker" style small cap, without the overhead bunk, so the gutters do not extend over the cab doors...
Wayne
2022 R-Pod RP-192
Old 01-14-2018, 01:15 PM   #8
JimOneil43's Avatar
My solution
Originally Posted by fliper74 View Post
Draining water from the gutter will drain right onto the interior door arm rest, right where the power window and lock switch are, when door is fully open. I am a big guy and cannot squeeze into the cab unless door is opened all the way. Any suggestions to correct this problem would be greatly appreciated.Attachment 160007
Well, We had the same problem because we live in Oregon and it does rain here !! This is what we did. Found a flexible tube and some pvc fittings at the home improvement store. A little pvc cement and a clamp and a few trial and error configurations and it works fine. The only problem is that I have to clean out the tube occasionally since we park near a cedar tree and it plugs up with needles. Easy to clean out though.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 01-14-2018, 01:34 PM   #9
PAPA T.
I like the ideal of the flexible tubing. Any other home fixes out there?
trozfast is offline   Reply With Quote
Old 01-14-2018, 02:17 PM   #10
Rokslinger's Avatar
X2 Plus purchase some adhesive gutter to redirect it away from the door, align it along the seam on the upper cab.
Dave Hammond
2017 FR Forester 3011 DSF
2013 Keystone Raptor TH
2013 Ford F350 Dually TV
Rokslinger is offline   Reply With Quote
Old 01-14-2018, 02:19 PM   #11
Following this . . . .
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 01-14-2018, 04:49 PM   #12
Bene Gesserit Rule
Murbella7's Avatar
If the setup is secure and doesn't flop around, split it to make it an open top gutter. Debris will wash away.
Murbella7 is offline   Reply With Quote
Old 01-15-2018, 05:43 AM   #13
DouglasReid's Avatar
Fast, Easy, Cheap and Effective. Im in!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-15-2018, 09:13 AM   #14
bareftn's Avatar
Use this when getting outa umbrella
bareftn is offline   Reply With Quote
Old 01-15-2018, 09:17 AM   #15
fliper74's Avatar
Sounds like a plan. Thanks for the feed back!!
Old 01-15-2018, 11:54 AM   #16
2012 Solera
From past forum posts, two relatively easy steps that can help -
1) Several have said clipping a clothes pin to the end of the gutter will result in the water running off the end of the clothes pin - effectively a two or three inch gutter extension.
2) Camping World (I think) has gutter extensions (what I used). These are an improvement, but still a little too short. A forum member said he made longer extensions from gallon milk jug handles. I have found GOOP works well to attach extensions.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-15-2018, 12:15 PM   #17
"Goop" marine adhesive?
McCormickJim
2017 GT 31L5
Old 01-15-2018, 02:54 PM   #18
2012 Solera
Quite honestly, I find all versions of GOOP about the same. GOOP marine adhesive should work fine... As will the original - Shoe Goo...
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-15-2018, 04:58 PM   #19
JimOneil43's Avatar
That might work some places, but here in Oregon in a heavy rain, it would just overflow on the sides.
Born April 18, 2016
GO DUCKS !!
