Has anyone replaced the vent in the rear bedroom? I would like to try and put in a fantastic fan but not sure of where the wires might run so that I an tap into. I have the 2081 qs gts forester.
Remove the inside trim you will see the wires. I swapped mine out. Not that hard just takes some patience to remove all the old dicor without damaging the roof.
I put a fan in the bedroom vent of my Sunseeker 3010DS.... Took the trim piece down and found the wires right there. Most difficult part was figuring which wire was positive and which was negative.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
I forgot to mention that I have a 2016 not sure if it was an option back then for wiring in the bedroom vent. It's in for warranty work so I haven't revisited that area
