Our 2016 2250 main bed has a split mattress. The split is angled, so the upper half slides up over the top of the lower (foot) half. Both halves have vinyl/fabric sides and bottoms, the top is fabric. It appears they were assembled & sewn with no access to remove the foam. The lower half is snapped to the floor of the slide, so it stays put in respect to the base.
If you really need to replace the mattress rather than give it a good cleaning, perhaps someone like the foamfactory.com or foambymail.com (same outfit) can help. We've replaced our seat cushions using foam from this business. You'll still need to make new covers, or have covers made. Be prepared - foam is expensive.
Regarding the seat cushions and overhead mattress, you could possibly zip off the covers and run them through the washer. That is, if they are in serviceable shape.
Good luck in whatever you do - but please, let us know what you did & how it came out.
On a personal note, I'd walk away from a unit that had been smoked in, and most likely would walk away from a unit that housed dogs. I've spent way too many years fixing things destroyed by other's dogs.
Smoke is almost impossible to remove, there will always be a faint smell.
That said, I realize there are a lot of dog owners out there. Kudos to you and your pup if it doesn't damage anything.
Smokers?? There is no excuse for it in this day and age.
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
