Your fridge should have a "fault" warning light if the propane does not ignite and you aren't connected to shore power, the fault light will come on. It's with the control display and temp display.
If you're cold already from shore power, it might not run when it's convenient. I always cool my fridge on shore power for about 24 hours, then about 4 to 6 hours before departure, I switch over to gas.
Purge your propane lines by running the kitchen stove for a few seconds until you get a smooth, consistent flame. Then, when the fridge starts, it must only purge the branch line from the main distribution line to the fridge burner. If you you start from cold and, maybe, just replaced a propane tank, the lines will be full of "air" and asking the fridge to purge all that air is asking too much. It's likely to fail repeatedly.
If possible, manually set your fridge to "gas", NOT "automatic." On auto, it will always switch to 120 volt shore power if you fire up the genny or plug in at a rest stop to, for example, run the microwave. Get it running on gas and force it to stay there until you get to a destination where you plan to stay that has shore power. This is particularly important if you have a small 2kw genny and you're boondocking. A big (6+ cubic feet) fridge starting on 120 volt power while running the micro or a hair dryer may overload the genny...from experience with a little 3 cubic foot fridge.
If there's no fault warning light and if there is heat coming out of the top fridge vent, you're running. They are actually very quiet compared to, for example, a hot water heater.
Good luck.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
