11-03-2015, 01:01 PM
#21
I have read several posts where people have just eliminated that filter and use a disposable one on the fresh water input outside. Seems to be a lot of problems with the factory installed one.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
11-03-2015, 06:54 PM
#22
I have had no problems with the factory filter and like the fact that it provides filtration for all water (in tank or shore), with no fuss or muss. I have winterized each year with air and anti freeze. I remove the filter canister, remove the filter, then pump AF. It fills the canister and pumps through the system. I dry the threads fully on the canister and have had no problems. A new filter cartridge in the spring and we are ready for another season.
2012 Forest River Sunseeker 2300 Chevy
11-03-2015, 07:06 PM
#23
Same here. I do use the tank more than hose so filtering that water is important to me as well.
B and B
11-03-2015, 07:53 PM
#24
Vaseline might not be food safe but that is what was used before Chapstick was invented maybe you are little young for that
2015 sunseeker 3050s. 2007 saturn aura
11-03-2015, 08:16 PM
#25
I removed mine and have a stainless bracket on the side of the trailer for it to hang on. I always use city water so I am not worried about the water in the tank or pump. I'll put it all back stock when I sell the trailer.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
11-03-2015, 08:43 PM
#26
Ayup...now we're showing our age. Ohhh how I remember Mom smearing that vasoline..
Personally, I don't use any O-ring lube. Keep the ring clean and make sure the cartridge is perfectly aligned with the down tube and screw it on until it makes contact. Go slow, take your time. Once it's on, give a gentle twist to tighten and Voila! The cartridge should be leak free.
11-03-2015, 08:46 PM
#27
X2 rattleNSmoke
11-03-2015, 10:07 PM
#28
No vaseline
I had similar filters for my sticks and bricks home. It is important to always relieve the pressure by turning turning on faucets and let system drain without the pump running. Always use a small amount of FOOD SAFE SILICONE on the "O" ring and the threads. A little goes a long way. Make sure the silicone lube is FOOD SAFE. And yes I have eaten vicks which is vaseline. Might be ok to ingest but it will interact with the rubber washers in the valves of the RV and you will have to replace them.
I didn't know the pump will drain the filter sump, got to try this, I hate juggling these canisters full of water.
Harry & Alice
Furkid Spruce
2014 Sunseeker 2650s
Friend of Bill and Lois
since May 30, 1975
11-05-2015, 10:31 PM
#29
Removing water filter
This has its advantages but then you will not have a filter on water coming OUT of the fresh water tank. Any dirt, sand or (worse) bacteria in the tank or its line will be pumped right into the coach lines.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
11-05-2015, 10:54 PM
#30
I don't have any problems with the filter I just blo lines drain hot water heater pump freshwater tank out the low point remove filter install cover back on if filter still clean put In ziplock bag until spring pink in traps little in black and gray tanks winterized
11-07-2015, 12:00 AM
#31
Are you so old that you learned to write before commas were invented too?! Haha!
11-07-2015, 12:57 AM
#32
Always Learning
Are you so uncooth that your momma never taught you that if you have nothing nice to say, don't say it at all? Sheesh!
11-07-2015, 01:50 PM
#33
You threw the first age hit back at #24 and his was intended as humorous "haha" it says. Let's all lighten up and get back to RVing? 😩😅
11-07-2015, 04:46 PM
#34
Love My Sunseeker
Whoever gave that tip about "turn on the water pump" and run water to drain it out of the filter cannister, IT WORKED!
I got my water filter cannister off EASY! THANK YOU!
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
11-07-2015, 04:53 PM
#35
Ever hear about the kettle calling the pot "black bottom"?
11-07-2015, 04:57 PM
#36
Better to use just a little Danco Silicone lube on the O ring. If nothing is used on the O ring, they seem to like to stick to the surfaces they touch. VOE!
11-07-2015, 05:08 PM
#37
Am I the only one here that has put a bypass kit on their water filter canister? It's the same kit as a hot water tank bypass and all you have to do is turn the lever remove canister dump water and winterize. No antifreeze gets to the canister and then in the spring, put the filter back in and turn the lever and you are back in business.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
11-07-2015, 05:24 PM
#38
I just don't see a need to do that. All you are doing is saving about a quart of anti-freeze. The stuff isn't that expensive to worry about a quart.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
11-07-2015, 05:46 PM
#39
Always Learning
Funny that you'd throw your hat into this ring. Welcome, Mr. Kettle.
11-07-2015, 05:53 PM
#40
I believe this is the simple secret that will cure all of the problems people have with the canisters blowing off.
Dan
2014 Berkshire 390RB-60
