I’m guessing this is the result of improper winterizing. Regardless of the cause you’ll need to replace the damaged line. Since it sounds like direct access to the damaged section is not possible you’ll need to find access farther down the line so you can remove the entire segment. See what’s on the other end of the sleeve. You might have to remove a cabinet or something else. Perhaps the sleeve will actually make it easier to extract the broken pipe.
2023 Forester 2351LE/2022 Chevrolet Express 3500
