Originally Posted by garbonz
That would be cool if it was true. I wonder how to tell that is happening, and at what voltage the batts kick back in.
Does operating at a constant 14.5 volts affect any systems, I saw a case where the equalizing cycle fried some led hockey puck light.
So much fun stuff to learn.
Battleborn told me that being held at 14.6 was not good, and PD told me they were working to develope a float setting for the LI converters, so that is all I know. I sometimes wonder if these folks are just telling us what we want to hear. I also unplug the power usually and also have 400 watts of solar and the Zamp controller and it works perfectly.
Hi Garbonz, your situation is very similar to mine. I just got off the phone with an Engineer at Battle Born. He said because of the concerns people had they did some accelerated testing at different voltages at and above 14.6V to try and determine if there would be any damage from maintaining a constant 14.5V on their batteries. He stated they could find no adverse effects of this to the batteries health or longevity.
Whether this affects any other systems in the RV time will tell. Most systems I have found have a range of between 12V and 15V listed that I have seen and many are OK for 24V or above systems. I am going to go through the specs on all my installed equipment and see what it states.
I very seldom plug in to ground power for any length of time except when prepping for a trip at home and usually that is for just a few days to cool the fridge. I have decided on a procedure, although probably unnecessary until more information is in on these relatively new batteries. I will shut off the 15A AC Circuit Breaker that goes to the Charger section of the Progressive Dynamics Power Center once the batteries are fully charged. This will allow my Zamp Solar Controller to maintain them at 13.4V. Luckily the Converter has its own dedicated AC Circuit Breaker.
I feel this is a small price to pay for the rapid charging the Lithium system allows when running off the Generator to top off the batteries in the late afternoon for unlimited power through the night.
I love the added benefit these batteries provide of being able to close the FW Slide without starting the generator especially when closing up for a 4AM start from a campground in the morning. I'm sure other campers appreciate it also. It's pretty amazing that they stay at or above 13V up to close to 80% depletion.
I am confident in my ability to keep an eye on the electrical systems in the RV and will continue to update information on results I find with use.
Before retiring in 2009 I spent 35 years as an Electronics Tech and Electrician on Aircraft in the Navy so hopefully I can figure out what I'm doing.
