Old 10-22-2020, 04:16 PM   #1
Sagecoachdriver's Avatar
Right Rear Bigfoot leveler won't fully retract
My Fortester has been sitting for about a year. I have used the levelers a few months ago to set my levelmatePro and they worked fine. Today I tried using them and the right rear goes down fine but only rises up 3/4 of the way, doesn't hit the pin switch but shows fully retracted. I cleaned the switch with contract cleaner and lubed the pin. I saw the push connectors to the switch were cracking and corroded so I replaced them. It still only goes up 3/4 of the way and shows fully retracted. Any ideas?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 10-22-2020, 04:20 PM   #2
Ambassador Member
Duckogram's Avatar
Will it go up in manual mode?
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 10-22-2020, 05:40 PM   #3
Fixed it, low on hydraulic fluid. I only use manual. Mine came with the non fully automatic. It has a leveler front to rear I think. But because I usually back into our favorite sites and have to raise the rears very high, I don't want the them coming off the ground and having nothing to prevent it rolling back and breaking the pistons. I works fine for me. Glad I had it happen at home and not up in Yosemite. I always carry a quart of HWH hydraulic fluid. Thanks
Old 10-22-2020, 06:01 PM   #4
Ambassador Member
Duckogram's Avatar
Glad that was an easy fix.
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 10-22-2020, 06:18 PM   #5
Question, the dealer had given me a quart of HWH hydraulic fluid when I had an issue the first year. That's what I used, but looking at the manual it says to use Dexron III. Are they compatible, maybe I need to call Bigfoot?
Old 10-22-2020, 06:28 PM   #6
Ambassador Member
Duckogram's Avatar
I remember a discussion on that subject a few years back. The verdict was that HWH is basically the same as Dexron III but without the red dye.
However, unless it reads full time use of Dexron is OK and not just for emergency, I would not use it. I say that not because of warranty issues but because I do not know if it will deteriorate gaskets/o rings or seals over time.
So Hello Quadra...
Ducky
18 Sunseeker 2800QS
Towing Smart
No PMs.
Old 10-22-2020, 06:29 PM   #7
Never mind, found it's the same as DexronIII but without red color.
