From your pictures it appears at least one of jack up position switches have a bent plunger. If it is bent the system will not properly sense if the jack is extended or fully retracted. The pins are easily replaced by unscrewing the switch and removing the damaged pin. The pins are standard 1/4” clevis pins, I believe they are 2” long.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
