Old 10-04-2015, 07:52 AM   #1
Roof vent problem
Has anybody had this problem? The crank up handle for the roof vent screws into a little box type thing the other side of the screen. The little box thing is separating (looks like a rivet holding it together separated) meaning the screw mechanism no longer works. Do I need to replace the entire roof vent or can I replace just the screw mechanism? If just the screw mechanism, is there a specific brand to get?
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 10-04-2015, 08:11 AM   #2
Fred H.'s Avatar
You can purchase them at most RV stores, amazon etc. Their pretty inexpensive and easy to change out.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 10-04-2015, 08:11 AM   #3
Just the mechanism. Had same problem. 20 min fix.
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 10-04-2015, 08:19 AM   #4
Thanks! Are they generic or do I need a specific brand matching whatever is in the sunseeker now? Are they done from the roof or inside (after removing the screen of course)?
Old 10-04-2015, 08:22 AM   #5
If I remember correctly from inside
Jerry. Vietnam vet.
Retired
Old 10-04-2015, 08:25 AM   #6
Yes inside 2 screws, home free
Jerry. Vietnam vet.
Retired
Old 10-04-2015, 08:43 AM   #7
VinceU's Avatar
As I recall there are 3 mfgr. take a picture of the outside hinge and match up at your retailer
Old 10-04-2015, 08:53 AM   #8
Drill the loose rivets out and just re-rivet or use a sheet metal screw. No need to replace it.
Old 10-04-2015, 10:59 AM   #9
Found just the the mechanism for $8.00 @ local RV store
goots is offline   Reply With Quote
Old 10-04-2015, 11:00 AM   #10
Great, easy fix
Jerry. Vietnam vet.
Retired
Old 10-04-2015, 12:07 PM   #11
OP here. I found a similar part at the local Camping World for $12. It's a knob instead of a crank arm. I took what I had apart, didn't measure the pieces, but this looks close. The only thing I can't figure out is where the little aluminum shim thing (by the knob in the picture) goes.
Name:	ImageUploadedByForest River Forums1443978464.104247.jpg
Old 10-04-2015, 12:21 PM   #12
VinceU's Avatar
Attachment 90617
Tensioner to keep knob from turning? Also ran Jensen and Elixir besides Ventline supply the vents
Old 10-04-2015, 01:33 PM   #13
OP here. No luck. The new part was a little different size and won't work. Now to try to find the right size. I'll check the Internet for the other names you mentioned. I don't think a new rivet or sheet metal screw would work either (I tried clamping the mechanism tight and it still doesn't work right).
Old 10-04-2015, 01:41 PM   #14
So remove it and see what is wrong with it.
Old 10-04-2015, 01:49 PM   #15
Cyber Phrenologist
Radio's Avatar
The arm has a gearbox on one end and a "round thing like a wheel" on the other. The "wheel" goes through the slot (or track) on the lid and the shim thing clips onto the wheel to hold it in the track.
Inspect your lid while you are doing this repair. A new lid is under $20 and while you are doing all of this you might as well change the lid, as they do not last long in UV light.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
Old 10-04-2015, 06:48 PM   #16
VinceU's Avatar
I think CW carries all three makes. Otherwise you can try PPL in Texas, they have enormous stock/availability. Easiest to ID by the hinge design.
roo, roof, vent
