Originally Posted by seagrace
Despite that I am fully LED in the camper, I still like to use the battery-powered lanterns and string lights ...
We still do the same ... when boondocking, we jealously hoard every last milli-amp-hour of the batteries for the fridge and furnace.
Regarding the
OP ...
Originally Posted by jjlavin
... we are doing a tailgate and I would prefer not to use the generator out of consideration of the people around us. My goal is to get the Crock-Pot cooking for 6ish hours off the batteries - I would use an inverter off the cigarette lighter adapter. I just checking the power that my Crock-Pot consumes. 2.25 amps, 278 watts.
My question - will my RV batteries be able to sustain that kind of power for 6 hours?
That is a huge draw on the batteries, as all the math preceeding this point makes.
Here is a "trick" we used successfully ... may or may not work in your instance ...
We prepared a crock-pot and used an inverter drawing off the TV electrical system. Since it was a several hour drive, we were able to leverage that cooking time and show up with it steamy hot.
Realise that this doesn't so much help if you are parked for many hours before serving time, but it is a way to leverage the power available while the wheels (engine) are turning.
Good Luck
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235
(previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
