02-25-2016, 10:38 AM
Rv compartment locks
We were told when we purchased the Rv that we should get new locks since everyone has the same key and theft can be an issue. Does anyone have a recommendation? There are some on Amazon, they seem to be between 5-$7.00 per lock also some are 5/8 others are 7/8? Which do we need? Also some us regular keys and others have the keys used on wheel locks. Thanks
02-25-2016, 10:44 AM
I swapped out our locks (and this assumes you have the same style) with file cabinet locks from Lowes. They are simple to swap out, and you can get them to all use the same key. Each package will have a 4 or 5 digit key code, just buy the number of locks you need with the same code, simple as that. I think they were in the $4.97 price range
Assuming this link works, this is pretty much what you are looking for.
http://www.lowes.com/pd_252974-76018...+cabinet+locks
But if you have the "handle style" locks, I am wasting your time, lol
_________________________
2019 Ford F250 Lariat 6.7 Powerstroke
2020 Cherokee Arctic Wolf 287BH
02-25-2016, 12:03 PM
Left Coast
Pull one out and measure first....and you can Google RV storage Locks..same thing for slam latches, although you'll be replac'n the unit as I'm not sure you can just git the lock..
02-25-2016, 12:08 PM
Replace the locks if you like but the likelihood of any one stealing your stuff is slim.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
02-25-2016, 12:23 PM
Agreed. And if it does happen, it won't be because they happened to have a key that fit your lock.
All the instances I've ever heard of an RV being broken into they either broke a window or simply pried the door(s) open.
02-25-2016, 12:28 PM
Soon as I get my camper back from the dealer I'm going this route, then my door key will also match the storage compartments.
Baggage Compartment Locks and Keys
I already rekeyed my rear door to match the front. These will make the whole trailer one key with the exception of the garage door. I'm not concerned about it from a theft standpoint, just pure convenience of 1 key.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
02-25-2016, 12:37 PM
This is the site I used to replace my RV locks. Simple process to order and to install.
2012 F150 FX4 Crew 5.0 3.73
2012Coachman Freedom Express 292BHDS (outdoor Kitchen)
02-25-2016, 12:54 PM
2012 Solera
Most of the discussions involve the wide use of the CH751 key. This is a small, single sided key. The compartments on our Solera use a double sided key - nothing like a CH751. Doubt your Sunseeker compartments use a 751 key.
JLeising
2012 Solera "S"
Calif SF Bay Area
02-25-2016, 01:26 PM
Originally Posted by Scubanut
This is the site I used to replace my RV locks. Simple process to order and to install. Attachment 100381
We used them too. They even sent me a new barrel when I screwed one of my new ones up. Great service and product.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
02-25-2016, 01:36 PM
Left Coast
I went to those, then went to slam latches...
02-25-2016, 02:12 PM
geezer with gadgets
Our Sunseeker had the 751 key on all outside storage and shower. We used the same distributor that Scubanut used and replaced them easily.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
02-25-2016, 03:42 PM
I replaced my 751's with barrel style locks. Mine were 7/8 on a forest river wildwood TT. Piece of cake and also really tightened up the door when closed and latched. Yes, if someone wanted in they can find a way but anything to slow them down and also avoid the "what if they just happened to have a 751 with them". Got them on Amazon. I replaced the one thumb turn latch with these as well so double locks on each baggage door.
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
02-25-2016, 03:52 PM
Can you remove the key when they are unlocked? Some you have to leave the key in or turn it back to the locked position to get the key out.
02-25-2016, 03:56 PM
No you can't. But honestly when I turn the key to unlock I just pull out a little on the key and then relock but the catch on the inside doesn't latch back to the frame. Piece of cake. Piece of mind.
02-25-2016, 06:44 PM
I used ILH also...great service and good locks. They'll also let you key them all alike, or have a couple that are different if you have that need. They'll even color code the keys. But as a someone else may have said, you need to measure every single lock you are replacing. For example, I used three different size configurations on my Sunseeker 3010 DS (2015). Just because they look the same doesn't mean they are.
02-25-2016, 10:24 PM
Who Dares, Wins
Changed my locks out this winder to the cam locks. They are much nicer to use and seem much better built than the cheap old locks FR put on. I did the locks a bit for security but mostly because the locks never worked great and the key was always very sloppy when put in the hole. I had a few times were things jammed up and not unlocking... Not anymore!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
03-09-2016, 09:20 PM
They can be removed if modified
03-09-2016, 09:22 PM
Left Coast
Look in locked compartment! Lol
03-09-2016, 09:23 PM
I filed the little tab off the cam lock keys so I could remove the key while it is unlocked and do the next lock. I also put 2 locks on each door.
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
03-09-2016, 09:27 PM
Left Coast
Wally757....My post was to follow yours..lol
