RVS Multiplexer
I have a SunSeeker 2300 that has the RVS-770619NA camera system that has given me problems off and on and I asked for help on here last year. I got the help I needed in finding it. The problem is the camera on the right side does not always come on so I can see when it’s safe to pull back over. It works very sporadically by coming on like 10 times in a row then not working for 50! Frustrating! I have taken the unit out from under dash, reconnected all the wires, did a hard reset by disconnecting the power as instructed by the factory and when I got finished I checked for a signal and it is just as good as the left side.
I am hoping someone has run into this problem and found a solution cause I’m at my wits end. I have talked to the factory multiple times and keep getting the same answer, no signal. What to do?
 . We are now retired and living the dream! 2014 2300 SunSeeker without slides that we remodeled inside for better living conditions for two people.
