Old 08-25-2020, 07:31 AM   #1
Question Safe T Plus installation
I have my stabilizer and bracket and plan to install this evening.
Question: Did you remove the existing Ford stabilizer?
Question: Did you just replace with existing Ford mounting brackets or did you completely remove the Ford parts and install per Safe T Plus instructions?
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 08-25-2020, 07:40 AM   #2
I installed the Safe-T-Plus on Ford E-450 following the company’s directions, which is to remove the Ford steering damper and it’s bracket, then install the Safe-T-Plus bracket and their unit. The Safe-T-Plus stationary mount is on the opposite side of frame from where the Ford damper had mounted.
I had to grind the base of the Safe-T-Plus bracket sightly to eliminate interference with the truck frame.
One thing that annoyed me was that the instructions gave no torque spec for the Safe-T-Plus stationary bracket mounting bolts. The company was no help, giving me erroneous answers at first, and finally telling me I had to contact Ford Motor Company for the answer.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 08-25-2020, 07:48 AM   #3
Originally Posted by BehindBars View Post
I installed the Safe-T-Plus on Ford E-450 following the companyís directions, which is to remove the Ford steering damper and itís bracket, then install the Safe-T-Plus bracket and their unit. The Safe-T-Plus stationary mount is on the opposite side of frame from where the Ford damper had mounted.
I just upgraded the front sway bar to the Hellwig so I know the torque specs for that bracket. They are 111 ft-lbs for the front and only 18 for the rear.
Cool, thanks!
Old 08-25-2020, 07:53 AM   #4
Cool, thanks!
Good to know the torque specs. Thanks.
Safe-T-Plus had originally responded to my question by telling me both bolts were to be tightened to 250 ft-lbs Anyone would see this would have certainly twisted the head right off the rear bolt, and likely damaged the front bolt.
Old 09-01-2020, 03:53 PM   #5
Usually Confused Member
emm-dee's Avatar
I had my ST+ installed at their headquarters. When they removed the Ford stabilizer they threw it onto a pile of Ford stabilizers in a big box. Must have been 50-60 of them in there.
2018 Forester 3051S (aka Clyde, the rolling roadblock)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 09-02-2020, 06:17 AM   #6
Hmm. That makes me wonder what mounting bolt torque they use for installations at their headquarters. Safe-T-Plus told me they didn’t know the torque specs for the Ford bolts that are used for attaching their own Safe-T-Plus bracket, and that I should contact Ford Motor Co. That leads me to think they are just guessing when they do their own installations.
Old 09-02-2020, 06:24 AM   #7
emm-dee's Avatar
Hmm. That makes me wonder what mounting bolt torque they use for installations at their headquarters. Safe-T-Plus told me they didnít know the torque specs for the Ford bolts that are used for attaching their own Safe-T-Plus bracket, and that I should contact Ford Motor Co. That leads me to think they are just guessIng when they do their own installations.
I watched them install mine and they did use a torque wrench. However, I donít know what torq spec was used.
Old 09-02-2020, 06:37 AM   #8
Safe-T-Plus does specify a torque for the other bracket that clamps to the steering linkage, so maybe that is where they were using a torque wrench. That bracket is easy to bend if over tightened.
