Old 07-16-2013, 11:13 PM   #1
wesslvm's Avatar
Satellite anybody?
Considering Dish Tailgater system. Has any one done this on your Sunseeker?
Wondering if I would have to run new coax or use exterior cable tv connector to connect dish to receiver inside.
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 07-17-2013, 05:57 AM   #2
osgood's Avatar
You can use the exterior jack, however you will need to access the av system to tap into the feed for all tv's in the coach.
osgood is offline   Reply With Quote
Old 07-17-2013, 04:43 PM   #3
how do you do this.
gerrym51 is offline   Reply With Quote
Old 07-17-2013, 07:26 PM   #4
osgood's Avatar
I can take some pics of my system and upload it tomorrow. Basically... Your A/V box should have a "From Cable" jack on the back. Since I use sat system that comes out of the back of the A/V box and into my sat receiver. The coax out from the sat receiver goes back into the "From Cable" jack on the A/V box.
Since my sat receiver box is right under the TV I run either Composite cable, or HDMI through the cabinet to the TV for the direct feed. The rest of the TV's in the camper get the broadcast from the coax input that comes from the A/V box.
Old 07-18-2013, 09:20 AM   #5
Motorized GM
Just had a meeting with the engineer to discuss this very set up osgood. I said before they make any changes they need to talk to me...most of these guys have one maybe two TV's. I've got 42" connected to Mac Mini, 70" connected to 7.1 surround, PS3, Zone 2 outside speakers, Dish Hopper, 42" to Roku box, etc. etc. All in HD.
So I think we have come up with a better design going forward. I'll run it past the forum when I get a print...but it should make it easier to hook up Sat or park cable. It's just tough to make it simple for those that want one TV and yet accessible for those that want to hook it up to everything. I think we have an acceptable compromise.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-18-2013, 08:16 PM   #6
wesslvm's Avatar
Bob, worth waiting before I make changes? I need HDTV up front at least, and at same time surround sound.
Wes
Honda CRV (TOAD)
Old 07-19-2013, 06:14 AM   #7
osgood's Avatar
Simple suggestion... Dual Coax ports for Sat and Park Cable.... Inside, Coax port available for sat connection into A/V box... The biggest thing would be easier access to the ports on the TV, whether it is a swing away panel, or removable panel.
Ill shoot a video today as I was not able to make it to the garage yesterday.
Old 07-19-2013, 08:01 AM   #8
Motorized GM
Wes
Just as a Side note...its Brian, I'm not sure where Bob came from (but you're not the only one).
This would be for new units. Just a simpler way to try and make sure we accommodate both park cable and sat. It can be done now..just not always as easy as it could be.
Old 07-19-2013, 08:18 PM   #9
wesslvm's Avatar
Sorry Brian, that WILL NOT happen again.
Honda CRV (TOAD)
Old 07-19-2013, 10:14 PM   #10
osgood's Avatar
Ok... So here is the A/V layout on my 3010ds...
Old 07-20-2013, 08:02 AM   #11
osgood's Avatar
Attached is the Magnadyne VCS10 connections I was not able to show in the video.
Name:	Screen Shot 2013-07-20 at 8.26.56 AM.jpg
Old 08-22-2013, 12:20 PM   #12
Thanks for posting this information. I have a couple of questions.
Why can the "Ext TV" only work with 4 of the sources (4 buttons on the front) while the other two TVs have all 5 sources? Which source is missing for Ext?
Old 08-22-2013, 12:25 PM   #13
Motorized GM
Aux2 is the one missing (at least in the picture) as for the why? You'd have to ask Magnadyne on that one. I think they make that box.
