Old 04-23-2016, 08:21 AM   #1
2015 Sunseeker 2300
screens added to water heater and furnace
I added screens to the water heater and furnace but did not want the edges scratching the side of the rv..so I added vacuum hose tubing to the edge...I think I did a pretty good job!
Name:	screen on rv.jpg
Gingsnap is offline   Reply With Quote
Old 04-23-2016, 09:58 AM   #2
Great idea! I think I'll do the same.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
gconley is offline   Reply With Quote
Old 04-23-2016, 10:11 AM   #3
Left Coast
Fridge and A/C to go...
Old 04-23-2016, 10:23 AM   #4
gectisme's Avatar
X2. Thanks!
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-23-2016, 11:02 AM   #5
bubbles's Avatar
Just out of curiosity, where did you add a screen to the water heater?
Old 04-23-2016, 11:21 AM   #6
2015 Sunseeker 2300
Mud Dauber Water Heater Screen - $18.99
here is a water heater screen I got mine from my dealer...
how would to add screens to the AC or refrig??????
Old 04-23-2016, 11:30 AM   #7
Nice!! where did you get them and how do they attach?
2020 Jayco Eagle HT 274CKDS
2018 Dodge Ram 3500 CTD SRW 4x4 Laramie
https://roaddivaontheroad.blogspot.com/
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 04-23-2016, 11:46 AM   #8
I attached screens to the furnace vents, fridge vents and water heater door last fall to both keep mice and wasps out of entering those areas. I got my screens from Amazon and they attach with springs except for the fridge vent screens which attach with plastic tie straps. All were easy to install.
lucky55616 is offline   Reply With Quote
Old 04-23-2016, 11:57 AM   #9
bubbles's Avatar
Well, OK. Are you not concerned with the very high heat transfer to the vacuum hose on the furnace screen? The intense heat generated there will burn you, thus the warning embossed on the outlet. Maybe it's OK. Just a thought.
Old 04-23-2016, 12:11 PM   #10
2015 Sunseeker 2300
got the screens from my dealer they attach with small springs very easy I did it..the black tubing is small vacuum hose from Auto Zone I sliced it down the middle and then slid it on the edges not sure why the makers of the screens do not have something to protect the side of the RV
Old 04-23-2016, 12:15 PM   #11
2015 Sunseeker 2300
the screen is well over the side of the furnace vent if it gets hot enough to melt the tubing then I would think it would melt the side of the RV plus doesn't vacuum hose get hot under a hood and not melt?? Humm I thought I was doing something good...
Old 04-23-2016, 12:17 PM   #12
Left Coast
Never had a scratch in over 2 years.....for the fridge and A/C, use alum. screening from HD or Lowe's, cut with scissors, and used alum. heat duct tape...
Sent from my XT1585 using Tapatalk
Old 04-23-2016, 12:23 PM   #13
dan-nickie's Avatar
Looks Good. Great job man!
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-23-2016, 12:32 PM   #14
Our service mechanics insist that we only use these screens when not using the appliance otherwise, they will limit their air intake and can actually cause serious problems. Check the manufacturer, they are the ones who told our techs.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 04-23-2016, 12:41 PM   #15
I also have heard that certain types of screen material may inhibit flow of air and have an adverse effect on operation, but I have never actually seen this in writing. It seems feasible - otherwise the factory would use a smaller gauge screen material.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 04-23-2016, 12:46 PM   #16
If you have square bumper caps cover those holes also,wasps/bees/snakes! Youroo!!
Old 04-23-2016, 01:27 PM   #17
I use no pest strips cut in small pieces and just set them inside the door of water heater, furnace or anywhere wasps or bugs get. They work great.
craig111 is offline   Reply With Quote
Old 04-23-2016, 02:42 PM   #18
rcla2014's Avatar
Here's a link to the ones you can buy on Amazon. You can get the at the dealer too. They have them for the water heater too. Do not need to put rubber on for protection.
https://www.amazon.com/dp/B00192JFBI/ref=cm_sw_r_sms_awd_d48gxbCJNJJGJ
rcla2014 is offline   Reply With Quote
Old 04-23-2016, 03:04 PM   #19
Found some stainless screen and mounted it under the intake/exhaust plate.
Found out NC mud daubers can get into the "add on" screens.
Name:	Furnace screen.JPG
Old 04-23-2016, 03:31 PM   #20
It may seem the screen is a little too large for your setup. I purchased a round set of screens that fit over each vent without going over the edge. It makes a tight seal against the Mud Dauber from entering. They are attracted to the smell of LPG. They are a large wasp and can sting if bothered. Not good to have aboard. The nest can also be blown up using a M-80.
Tropiccafe is offline   Reply With Quote
furnace, heater, water, water heater
